bed rail protectors
Old Apr 21, 2003 | 03:31 PM
saintthomas's Avatar
saintthomas
Question bed rail protectors
Hey folks,
I bought a set of UWS bed rail protectors today. The kit comes with three screws for each side. This sounds nuts to me! Seems like you would want some two sided tape under there. My question is for those people who have these protectors. How are yours held on? If you use the screw, where are they?
Old Apr 21, 2003 | 03:54 PM
Rockledge's Avatar
Rockledge
bed rail protectors
I have Wade bed rail guards. Put them on myself, easy as pie, and they fit perfect. I cleaned off certain areas of paint along the top of the rails with alcohol, like the directions said, preparing them for the two-sided tape, one side of which was already stuck on the guards themselves. So after cleaning the paint it was simply a matter of peeling back the protective cover off the tape, and then placing the guards into proper position on the bed rails. No screws, but then the guards aren't metal, either.
3M makes a tape especially for car trim and it's tough as nails: 3M Automobile OEM Attachment Tape
Old Nov 13, 2004 | 12:43 AM
2K3 Mach's Avatar
2K3 Mach
Rockledge,
Do you have any pictures of your bed rail covers?
My buddy put a set on his ZR-2 and they already look like they're 1/2 way from coming off.
I removed an old tonneau cover, and I want to cover up the scratched paint.
It seems like any aftermarket that uses 2 sided tape would eventually come off.
Also, with the wide bed rail, I wouldn't think anything would fit snugg like the F-150's.
Thanks
Old Nov 13, 2004 | 06:04 AM
Rockledge's Avatar
Rockledge
I don't have any pics of the bedrails themselves, but if you look at the "Ford Pics" in my signature you can see how they look from the side. As I noted, the fit is perfect.
I have had no problem whatsoever with the bedrails staying put, they look as good as good now as they did a year and half ago when I put them on. Believe me, if you get the right rails for your application, and if you install them properly, then you won't have any problems with durability.
Old Nov 13, 2004 | 08:00 AM
2K3 Mach's Avatar
2K3 Mach
They do look tight.
What brand are they and where did you get them?
Did you use additional 2 way tape? You mentioned the addtional 3m tape, but did you need to use more?
Thanks, and nice pics.
Another unrelated questions... How do you get you sig in the actual body of the post?
Old Nov 13, 2004 | 08:16 AM
Rockledge's Avatar
Rockledge
The rails are made by Wade.
I did not use additional tape on mine.
Having a signature show up below a post is one of the "perks" of joining Club FTE.
Old Nov 13, 2004 | 09:11 AM
kontai69's Avatar
kontai69
I have and highly recommend the Bak Industries ProCap (http://www.bakliner.com/procaps.htm). The fit and finish is excellent. It is secured with super strong adhesive tape. There is now way it is coming off. I got it at stylinconcepts.com
Here is a pic...
http://memimage.cardomain.net/member...138045full.jpg
IMO, the "ultimate" bed rail protector would be a spray-on liner like Line-X. Have them do the rails when you get the bed done.
2.5L four
http://www.cardomain.com/id/kontai69
User 71024
Apr 27, 2014 03:53 AM
84-250
Appearance & Dress-Up
Mar 30, 2005 07:27 PM
FordMan190
Feb 18, 2004 10:54 PM
71swissaqua
13
Jul 14, 2001 09:29 AM
