Mercon or MerconV
Old Jan 26, 2012 | 09:49 PM
BigAlsPSD's Avatar
BigAlsPSD
Sorry OP.
Best towing setup in my opinion would be good custom tuning. Single shot injectors, and either a van turbo or 38R, with the motor hooked to a BTS(Brian's Truck Shop) or John Woods Tranny. Done, highly reliable, proven setup.
As for the wastegate, just adjust it properly, and don't worry about it. Until you are high boost pressures, I wouldn't worry. If you went really high boost then you might add a wastegate simply to relieve back pressure.
Old Jan 26, 2012 | 10:15 PM
renyren's Avatar
renyren
all good on the hijack but any one else running mercon v instead morcon?
Old Jan 26, 2012 | 10:35 PM
Stewart_H's Avatar
Stewart_H
Renyen, do you know how long ago Ford stopped recommending Dex III/Merc and started recommending Mercon V? It's been years...at least 5 years ago.
Ford and GM no longer license Dexron III/MERCON. Nobody is watching what's in them. MERCON V is licensed by Ford so there is some monitoring the fluid.
But it's your choice. Use a fluid no longer recommended by Ford (Dex III/Merc), or use the one recommended by Ford (Merc V).
Stewart
Old Jan 27, 2012 | 08:19 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
From what I understand, Mercon is not made anymore, only Mercon-V.
Old Jan 27, 2012 | 03:26 PM
Stewart_H's Avatar
Stewart_H
It disappeared for awhile, Rick, but it's back on the shelf now. At least it is in Autozone and Kragens.
But that info I posted above, Ford licenses Merc V now, not the Dex III/Merc, is from Mark Kovalsky.
Stewart
Old Jan 27, 2012 | 04:18 PM
white Buffalo's Avatar
white Buffalo
Originally Posted by Stewart_H
Renyen, do you know how long ago Ford stopped recommending Dex III/Merc and started recommending Mercon V? It's been years...at least 5 years ago...............
Stewart
My 2006 Lubrications Guide still shows Mercon as the recommended fluid, so I think it was after 2007........
Old Jan 27, 2012 | 04:34 PM
Stewart_H's Avatar
Stewart_H
You made me look...LOL.
It was June of '06.
TSB
06-14-4 MERCON ATF IS BEING REPLACED BY MERCON V ATF AS A SERVICE FLUID.
Publication Date: June 29, 2006
FORD: 1980-1997 Crown Victoria
1981-1997 Mustang, Thunderbird
1981-2003 Escort
1986-1993 Festiva
1986-1997 Taurus
1989-1997 Probe
1994-1997 Aspire
1995-2000 Contour
1980-1996 Bronco
1981-2003 F-150
1981-2004 E-Series, F-Super Duty
1983-1996 Ranger
1986-1996 Aerostar
1991-1997 Explorer
1993-2004 F-53 Motorhome Chassis
1995-1998 Windstar
1997-2004 Expedition
2000-2005 Excursion
2001-2007 Escape
1987-2000 F- & B-Series
2000-2007 F-650, F-750
LINCOLN: 1980-1997 Town Car
1981-1997 Continental
1993-1997 Mark VIII
1998-2004 Navigator
2002-2003 Blackwood
MERCURY: 1980-1997 Grand Marquis
1981-1997 Cougar
1986-1997 Sable
1987-1999 Tracer
1995-2000 Mystique
1999-2002 Cougar
1993-2002 Villager
1997 Mountaineer
2005-2007 Mariner
MERKUR: 1985-1989 XR4TI
This article supersedes TSB 01-15-7 to update the vehicle application chart.
ISSUE:
MERCON® Automatic Transmission Fluid is being replaced by MERCON® V as a service fluid.
ACTION:
Beginning immediately all automatic transmission / transaxle applications requiring MERCON® can now be serviced using MERCON® V or MERCON® Automatic Transmission Fluid or dual usage fluids labeled MERCON® / MERCON® V. After July 1, 2007, MERCON® Automatic Transmission Fluid will no longer be manufactured, therefore, availability of this fluid will only continue for however long it takes to deplete what remains in inventory.
SERVICE PROCEDURE
Service automatic transmissions requiring MERCON® with MERCON® V or MERCON® Automatic Transmission Fluid or dual usage fluids labeled MERCON® / MERCON® V
For proper fluid application on current and past model vehicles equipped with automatic transmissions / transaxles refer to the fluid usage chart. (Figure 1)
CAUTION: AUTOMATIC TRANSMISSIONS / TRANSAXLES THAT REQUIRE MERCON® V SHOULD STILL ONLY USE MERCON® V OR DUAL USAGE FLUID LABELED MERCON® / MERCON® V.
CAUTION: MERCON® SP, MOTORCRAFT PREMIUM AUTOMATIC TRANSMISSION FLUID AND MOTORCRAFT M5 ATFS ARE UNIQUE FLUIDS AND MUST BE USED IN APPLICATIONS RECOMMENDING THAT PARTICULAR FLUID. USE OF ANY OTHER FLUID MAY CAUSE REDUCED FUNCTIONALITY OR TRANSMISSION DAMAGE.
CAUTION: THE FUNCTIONAL CHARACTERISTICS OF FLUIDS FOR CVT TRANSMISSIONS ARE VERY DIFFERENT THAN THOSE OF OTHER AUTOMATIC TRANSMISSION FLUIDS (ATFS). USE OF A FLUID OTHER THAN MOTORCRAFT CONTINUOUSLY VARIABLE CHAIN TYPE TRANSMISSION FLUID OR ONE LABELED AS MEETING MERCON® C WILL CAUSE FUNCTIONALITY CONCERNS AND INTERNAL TRANSMISSION DAMAGE.
CAUTION: DO NOT USE AUTOMATIC TRANSMISSION FLUID SUPPLEMENTS, ADDITIVES, TREATMENTS OR CLEANING AGENTS.
PART NUMBER PART NAME
XT-2-QDX MERCON® (Quart)
XT-2-DDX MERCON® (55 Gal. Drum)
XT-5-QM MERCON® V (Quart)
XT-5-DM MERCON® V (55 Gal. Drum)
WARRANTY STATUS:
Information Only
Stewart
Old Jan 27, 2012 | 06:48 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
How about synthetic? Last time I changed mine I used synthetic, but after seeing what it cost now... Yikes. I think I will skip the synthetic and get an external filter for this change anyway. What are most people running?
Old Jan 27, 2012 | 10:40 PM
white Buffalo
I run Schaeffer's 204SAT synthetic transmission fluid. The same fluid BTS uses in all their trannys. Good for approx 60K (twice that of dino fluid) depending on the work environment. Runs about $120 for 5 gallons. I use 18 quarts in the tranny and whatever is leftover goes in the power steering.
Old Jan 27, 2012 | 11:53 PM
renyren's Avatar
renyren
just wanted to give an update. Today I put the new JW valve body in and changed the filter and all new Mercon V fluid. Thanks NICK. Very little driving but so far very impressed, truck shifts better.
Old Jan 28, 2012 | 07:51 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
I looked it up it's over $200 for 5 gallons now. That's about what mobil 1 is give or take.
Geotruck
Aug 15, 2010 06:28 AM
nolanb
May 11, 2010 06:27 PM
1978Crew
Escape & Escape Hybrid
20
Jan 2, 2008 07:25 PM
exiled
Jul 14, 2007 07:25 AM
miichael
Mar 10, 2006 04:49 AM
