I recently asked about what type of transmission fluid to put in my 1996 ford explorer 5.0 and i was told that mercon v would be fine. However after doing more research i found this article.
Type F — Introduced by Ford in 1967 for their automatics. Also used by Toyota.
Type CJ — Special Ford fluid for C6 transmissions. Similar to Dexron II. Must not be used in automatics that require Type F. Type H — Another limited Ford spec that differs from both Dexron and Type F. Can be replaced with Mercon.
Mercon — Ford fluid introduced in 1987, very similar to Dexron II. OK for all earlier Fords, except those that require Type F.
Mercon V — Ford’s newest type, introduced in 1997 for Ranger, Explorer V6 and Aerostar, and 1998 & up Windstar, Taurus/Sable and Continental. Must not be used in 1997 or earlier Fords.
Dexron — General Motors original ATF for automatics.
Dexron II — Improved GM formula with better viscosity control and additional oxidation inhibitors. Can be used in place of Dexron.
Dexron IIE — GM fluid for electronic transmissions.
Dexron III — Replaces Dexron IIE and adds improved oxidation and corrosion control in GM electronic automatics.
Dexron III/Saturn — A special fluid spec for Saturns.
Chrysler 7176 — For Chrysler FWD transaxles.
Chrysler 7176D (ATF +2) — Adds improved cold temperature flow and oxidation resistance. Introduced in 1997.
Chrysler 7176E (ATF +3) — Adds improved shear stability and uses a higher quality base oil.
Genuine Honda ATF — Special ATF for Honda automatics.
Toyota Type T — Special formula for Toyota All Trac vehicles and some Lexus models.
Says use mercon v in only 1997 and newer fords? It says mercon is for 87 and newer ford where dexron 3 is for gm. Will Dexron III/Mercon be fine? I cant find just mercon.
What brand of Mercon V do I need to buy? I dont want to buy it from ford but I dont want walmart brand. Would like a good name brand fluid. Any suggestions?
any fluid that meets the ford spec will be fine. if the supertech brand from walmart did come in mercon v it would be a sellout they have a hard enough time keeping the mercon in stock. From the UOA it is a stout oil which can run with the big boys.
