Sponsored by: Auxito
Flywheel\Starter Issues
Old Jan 25, 2012 | 03:52 PM
Hybris's Avatar
Hybris
For the last year and a half or so every once in a while I will go to start the truck and get a loud grinding noise without the truck starting.
Now when this happens usually the second time I try to start the truck it starts up normally with no signs that anything is wrong, but as of late a few times it grinds twice before starting and twice it took 3-4 grinds before starting.
Now in the past I have replaced the starter when this same problem came up and it solved it for a time but now I am thinking its something to do with the flywheel.
Any input would be a great help.
Tomorrow I'm going to take off the starter and figure out how to push the flywheel around so I can do a visual inspection and see if I am missing teeth but I am not sure how or even if I can manually push the flywheel around so any advice on that as well would be valued.
On other question is are the starters the same on the V10 as they are on the 5.4 motors?
Old Jan 25, 2012 | 03:59 PM
Archion's Avatar
Archion
Veteran: Marine Corps
Best way to turn the motor is to use the bolt in the crank that holds the balancer on and a large ratchet. Yes both motors from 99-06 use that same starter. (Lester# 6646)
Old Jan 25, 2012 | 08:59 PM
steve(ill)'s Avatar
steve(ill)
bad teeth, miss alignement of the starter, or weak bendix are all possibilities.
Old Jan 26, 2012 | 01:56 AM
Hybris's Avatar
Hybris
What would that be and where is it on the truck if I may ask?
Old Jan 26, 2012 | 04:49 AM
Archion's Avatar
Archion
Bendix drive - Wikipedia, the free encyclopedia
It's part of the starter.
Old Jan 27, 2012 | 08:47 PM
Hybris's Avatar
Hybris
Well didn't get around to checking the flywheel but I will post here when I do to share my results but it might be a week or so till I do.
Thanks so far for the help given.
Old Jan 28, 2012 | 12:18 AM
Moore558's Avatar
Moore558
I had a friend with a 99 F150 and his truck was doing the same thing. He replaced the starter and it was still grinding and not catching to start the truck at times. I decided to pull the starter and check the teeth on the flexplate and this is what I saw...
New flexplate later and he was good to go. Hopefully you'll have better luck than he did.
Old Jan 28, 2012 | 12:42 AM
whitefordexplorer's Avatar
whitefordexplorer
WOW.... thats bad..... possibly the worst ive ever seen!
Old Jan 28, 2012 | 12:53 AM
Moore558's Avatar
Moore558
Yeah. My friend was wondering why I cursed in German after seeing that.
Old Jan 28, 2012 | 01:02 AM
whitefordexplorer
i pulled a starter from an '82 f-150 with a 5.0 the other day that the bendix gear blew apart.... and i have never seen that before.... my boss couldnt figure out why i was laughing so hard....
Powerstrokin7.3L
Oct 10, 2012 11:35 PM
cartune
1997 - 2003 F150
Jan 1, 2007 08:20 PM
equium
Mar 30, 2004 10:09 AM
liljpy
Electrical Systems/Wiring
Oct 16, 2002 10:43 PM
BeeterTruck
Sep 3, 2001 09:54 PM
