1999 PSD starter problem
Old Oct 4, 2012 | 06:44 PM
Powerstrokin7.3L's Avatar
Powerstrokin7.3L
Unhappy 1999 PSD starter problem
i have a 1999 ford f250 psd with a 7.3l and i just returned from a deployment in afghanistan and the first day im back i take my truck out for a drive it started fine but made a little noise starting up then it was fine i drove around for awhile then i went to the bank wen i went there i turned off the truck and went inside then wen i came out and tried to start it it made a horrific grinding noise i immediatley new it was the starter so i took the inspection plate off to see if there was anything wrong. there was nothing so i had my wife start it while i was underneath and the pinon gear was contacting the flywheel but it wouldnt turn the flywheell it would just spin and grind against it. so i manually turned the flywheel a little and tryed it again and it started with some horrific grinding noise with it so i took it home and removed the starter and it didnt look bad. so i thought it might have been the starter being loose so i installed it again and made sure it was tight and went to start it and the same grinding happend and the flywheel would not turn so i went to autozone got a new starter and replaced it and again the same grinding noise with no start to fallow so i just got back from returning the starter and just want to know if there is any other options other then replacing the flywheel because thats gonna be a job lol...any incite would be very appreciated......ford trucks rule!
Old Oct 4, 2012 | 06:56 PM
1fixitman's Avatar
1fixitman
I have not heard of any fly wheels going bad on this forum. I would have to dig deep to help you out on this one. I would start a new thread titled flywheel problem and then copy and paste your first post from this thread to the new thread so you get a few more people that may have some experience with replacing the flywheel. Sorry to hear about this. I am positive that if this is the true problem that you have to drop the transmission. I would love to see a picture of the old flywheel sitting on top of the new flywheel to see the difference in tooth depth only if you have to do that job.
Edit: I forgot to ask how many miles are on your truck?
Dwayne
Old Oct 4, 2012 | 07:06 PM
Powerstrokin7.3L
thats a good idea i will do that, and in hoping that i dont have to replace the flywheel i will defanitley take pictures of the job to show the difference in new and old. my truck has 183000 miles on it and it was perfectly fine wen i left 6months ago and now all of a sudden its doing this....appreciate ur reply thank you.
Old Oct 10, 2012 | 07:57 AM
koski19's Avatar
koski19
About 18 months ago I had the same problem with my 99. Engaged the starter and it would grind against the flywheel. The problem would be intermittent. Sometimes grind sometimes not. Eventually, I too pulled the starter and rotated the flywheel and found that several teeth on the flywheel were worn down. I decided to replace the flywheel however I kept the old starter. Then in October of last year I decided to changed out the starter with one from Napa #STR7006 built by NSA. Fast forward to 2 weeks ago. I started having starter grind again.
Yesterday, I pulled the starter and found that the starter was wearing off the teeth in several locations on the new flywheel. The starter will grind down the teeth rather fast. I recall the grinding only happened about 10 times in the past 2 weeks. I took the starter back to Napa. Napa then traded straight across for a new Napa #4N-6770 gear reduction starter. The starter price is $189.79. Installed the starter and what a difference in starting the truck and so far no grinding. I still may replace the flywheel but will wait for now. It is a big job.
The reason for the starter grinding is that the Bendix is weak and doesn't allow the gear to come out far enough to engage the flywheel. I would recommend that you replace with a gear reduction starter. It will reduce the draw on the batteries and start your truck faster than the stock unit. I think you'll be happier. Also, the part number I gave for the gear reduction starter is a Napa lifetime warranty starter.
Hope this helps out.
Jeff
Old Oct 10, 2012 | 08:44 AM
stinson 108-1's Avatar
stinson 108-1
stinson 108-1
The selenoid is probably weak as stated above. Both types of starters are gear reduction. One is planitary, the other is off set. Get the 3 bolt your truck came with. OEM. The rebuilder I use gets (new) motorcraft for 225.00. Tousley has reman. in the US for Ford for about 175 with core. I have one for my spare. Don't quote me on the price, but thats close. Got it this summer.
Old Oct 10, 2012 | 03:47 PM
Powerstrokin7.3L
figured out its the flywheel turned the crankshaft a little bit then started right up but after two starts in wont so i turn it manually again then bam starts again....got a new problem now though wen i take my key out a relay goes crazy and wen i turn it to the on position i lose all power.....damn this truck is cursed i swear
Old Oct 10, 2012 | 07:16 PM
dn29626's Avatar
dn29626
I had a similar problem a while back. A local rebuilder repaired the starter by replacing the drive (of the starter) .
Old Oct 10, 2012 | 11:35 PM
Powerstrokin7.3L
these damn trucks lol i put a new starter in and it wasnt the problem but now i gotta pull the tranny to replace the flywheel fml......probably just gonna upgrade the tranny while its out too
buffy.mike
Feb 25, 2011 11:58 AM
randomhero1172
15
Mar 4, 2009 03:51 PM
cartune
1997 - 2003 F150
Jan 1, 2007 08:20 PM
sadbroncowner
Bronco II
Dec 20, 2005 10:50 AM
bronco Jr.
3.8 & 4.2L V6
Jul 25, 2003 09:48 AM
