Pulled FPR out but did not find the screen. Is the screen behind the spring and triangular metal piece? Do you have to remove something else to get to the screen?
also there are 2 connectors on each valve cover with 5 wires on each plug. they controll your glow plugs and injectors. every now and then they will burn up. try unplugging each connector and look for burnt pins or bad wiring going to the connector. also take off the oil fill cap and passenger side valve cover and smell for a burnt smell.
mitch
Took fuel bowl assembly off the truck that was not runniing and put it on my truck and it started right up. Gonna pull IPR tomorrow and check that in truck that runs.
Gonna pull icm and check that. He tried putting my IPR on his truck and still nothing. If ICM swap does not do the trick he is gonna take it to the shop.
