97 PSD fuel issues
Old Jan 24, 2012 | 01:27 PM
sparke454's Avatar
sparke454
97 PSD fuel issues
Hello All
my buddy has a 97 PSD with a bunch of miles on it. He went to start it up the other day and it would not fire. sprayed it with ether and she would run until the ether ran out. If he kept spraying the ether it would stay running. So I suggested changing the CPS. He did that and still same issue. Changed fuel filter and same issue. Anyone out there have any other suggestions?
Old Jan 24, 2012 | 02:34 PM
427 fordman's Avatar
427 fordman
What's the fuel pressure?
Unless he has the glowplugs unhooked he better quit using the ether like that or he will have big problems.
Old Jan 24, 2012 | 02:47 PM
sparke454's Avatar
sparke454
Unsure of fuel pressure. Checked maxi fuse under hood and it is good.
Old Jan 24, 2012 | 03:06 PM
79f-250custom's Avatar
79f-250custom
check the ipr o-ring and maybe even injector o-rings.
Mitch
Old Jan 24, 2012 | 03:17 PM
Copedawg's Avatar
Copedawg
STOP with the ether! please. What were the symptoms when it stopped running?...NEVER MIND I see it is a sudden no start. Has he done any work on it recently? Is it cold there...have good batteries?
#22 fuse is good? good. Need a fuel pressure reading (to see if it is fuel related). Does it smoke when it cranks? (if no...then it may not be a fuel problem)
Should be at least 40PSI but no more than 75(?)...while cranking with VERY GOOD (jumping it) batteries
Help us help you/your friend.
Old Jan 24, 2012 | 03:35 PM
sparke454's Avatar
sparke454
my buddy does not recall it smoking while cranking the truck.
do you need a special fuel pressure gauge to take the reading?
Old Jan 24, 2012 | 04:08 PM
MHammer21's Avatar
MHammer21
a simple tire pressure gauge will work, you can see the test port in the pic above, middle of the pic just to the right of the fuel filter.
Old Jan 24, 2012 | 04:10 PM
Copedawg's Avatar
Copedawg
if it is not smoking at cranking then it may not be fuel related.
Does he have a "Cali" model?...Does he have a blue sticker on the right (passenger) side valve cover? Can he get any codes from a OBDII reader?
Old Jan 24, 2012 | 04:11 PM
Copedawg's Avatar
Copedawg
The "HAPPY HOUR" crew should be in shortly to get more ideas
Old Jan 24, 2012 | 04:15 PM
sparke454's Avatar
sparke454
the fuel pressure test point will not squirt fuel when the center is depressed
Old Jan 24, 2012 | 04:17 PM
Copedawg's Avatar
Copedawg
You got to be cranking when you check it, Brother (2 man task)
Old Jan 24, 2012 | 04:19 PM
427 fordman
Sould be at least 20 psi cranking. Is there fuel in the bowl?
Old Jan 24, 2012 | 04:21 PM
Copedawg's Avatar
Copedawg
yup 20 cranking...40 or so idleing
Old Jan 24, 2012 | 04:22 PM
sparke454's Avatar
sparke454
the truck is from tenessee. he does not rcall seeing a blue sticker on the valve cover
Old Jan 24, 2012 | 04:23 PM
sparke454's Avatar
sparke454
the fuel bowl does have fuel in it.
he pulled the fuel filter out and cranked the engine over and the bowl was not filling very fast at all
