Life Pump
Old Jan 24, 2012 | 12:16 PM
Crazy2's Avatar
Crazy2
Question Life Pump
OK got ? here i want do away with the LP on motor that because my wife had go to Ga. yesterday and on her way back truck ran out fuel she said there was 1/8 tank in the front tank and there was 3/8 of fuel in the rear and that what she was running on she getting ready get off ramp truck just die on her and ended up coasting 250.00 for some come out bleed the system so here want do i have elect. life pump from my 6.5 chevy can used that with out hurting the fuel system
Bruce
Old Jan 24, 2012 | 12:39 PM
Jayme Duty's Avatar
Jayme Duty
you can use an electric lift pump. you have to remove the stock lift pump and get a block off plate. I am not sure if the pump from your chevy will work or not.
Old Jan 24, 2012 | 03:44 PM
tjc transport's Avatar
tjc transport
i ain't rite
yes you can put an electric pump on. but remember, these trucks are known for the fuel pickup in the tank cracking at around the 1/4 tank mark and sucking air instead of fuel. so even with an electric lift pump, if the pickup is cracked you will still run out of fuel when it hits that mark.
that is why a lot of us never let the fuel gauge go below 1/2 tank.
Old Jan 24, 2012 | 03:55 PM
Crazy2's Avatar
Crazy2
Yes i under stand the pickup can go bad and i have one that bad but will be fix this weekend just want make easy if this happens again so the wife just turn key after added fuel and make little easier for her. Hopefully she will never run down that low again
Can some tell me what size line going to LP is and do they make block off plate for the LP or do have to make one
Thanks Bruce
Old Jan 24, 2012 | 04:08 PM
tjc transport
i ain't rite
big block chevy fuel pump block off plate is a perfect fit.
Old Jan 24, 2012 | 04:12 PM
Crazy2's Avatar
Crazy2
Thank for that info
Old Jan 24, 2012 | 05:06 PM
Crazy2's Avatar
Crazy2
Other ? here about the fuel do these truck have a Diesel Fuel Injector Driver Module of is that just the PS that has it
The reasoning i am asking i guest still have fuel problem the truck wouldn't start for the wife again fuel filter was full of fuel. do these IP have screen on the inlet on the IP and before ask yes the glow plug system is working great truck started fine this morning and when she went out lunch no start
Old Jan 24, 2012 | 05:08 PM
Crazy2's Avatar
Crazy2
where can i get pickup tube for the rear tank ?
Old Jan 24, 2012 | 05:55 PM
Crazy2's Avatar
Crazy2
Other ?? what is the sensor on fuel for and how dose it work
Old Jan 24, 2012 | 07:30 PM
tjc transport
i ain't rite
idm is powerstroke.
the IDI does not have it.
sensor on fuel?
are you talking about the one on top of the filter head?
that is the fuel heater.
Old Jan 24, 2012 | 09:18 PM
Crazy2's Avatar
Crazy2
idm is powerstroke.
sensor on fuel?
yes the that in the housing
Dan656
Aug 22, 2018 10:34 AM
FordAnne
Nov 11, 2017 11:03 AM
beersy50
Nov 28, 2008 12:11 AM
70Post455
Jan 4, 2008 02:49 PM
tony b
Nov 4, 2006 10:10 AM
