Modular V10 (6.8l)
ABS light
Old Dec 18, 2008 | 08:45 PM
<TDUB>'s Avatar
<TDUB>
Question ABS light
Hello I have a 2000 F250 SD V10 the (ABS) light is on all the time ???
Old Dec 19, 2008 | 09:20 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
You really need to get the codes read, using a scanner that can read ABS codes (most cheapo ones can not).
However, the one reason the ABS light comes on that will not throw a code is LOW BRAKE FLUID in the master cylinder reservoir.
Old Dec 19, 2008 | 09:27 AM
jonrjen's Avatar
jonrjen
One of the most often causes is a bad wheel sensor. However, as Krewat said, use a good code reader and you can narrow down the problem.
Old Dec 19, 2008 | 12:56 PM
wfof250v10's Avatar
wfof250v10
I've had the ABS light come on in my truck and wifes car. I read the codes in the truck and the code came up as rear sensor something.?!?.. I checked under the truck, pulled the wheel and then reset the PCM on the truck and the light never came back on and that was over 2 years ago. I reset the PCM on my wifes car with out reading the codes because I don't have a scanner for her car, but resetting it on hers the light never came back or atleast she never told me about it coming on again.
Old Dec 19, 2008 | 04:23 PM
<TDUB>'s Avatar
<TDUB>
thanks for the info!
Old Dec 20, 2008 | 02:01 PM
V10'nr's Avatar
V10'nr
Abs
I have the same year. I changed out my wheel sensor and it fixed the light problem.. The sensor is not that expensive and easy to do. It is located in the rear diff. That sensor sticking out of the top is it. One bolt and alittle muscle and out it pops. I also noticed that before I changed it the speedo would stop moving some times. Now no problems.
Old Dec 22, 2008 | 12:34 PM
V10_Cougar's Avatar
V10_Cougar
You must be reffering to the Vehicle Speed Sensor.
Old Dec 22, 2008 | 01:03 PM
V10'nr's Avatar
V10'nr
abs
Yes sir, I was talking about the speed sensor.
Old Dec 22, 2008 | 01:36 PM
wiingnut's Avatar
wiingnut
my vote is for the speed sensor also. Had same issue with my last truck
Old Dec 25, 2008 | 10:44 AM
Skullonarm's Avatar
Skullonarm
If your going to change the VSS make sure to use a 3/8" socket, and not the 10mm. The ten will fit, but if the bolt is tight the 10mm might round off the corners of the bolt head, and makes the bolt almost impossible to remove. Seen it happen. Also you can spray some brake clean through the slots on your wheels aiming at the sensors and clean them up a bit, Or remove the wheel to get a better shot at it. Start simple and work up. Is the master cylinder full? If not your brakes are worn and a lot of the fluid is in the lines to make up for the decrfese in pad thickness. Add fluid and check for abs light. Just remember through when you change your brake pads someday, that is if you do your own work, before you compress the brake caliper pistons remove some of the brake fluid from the master cylinder or you will have a nasty mess on the wheel well paint and else where. This stuff will remove paint.
Jaaaaaaackman
Dec 27, 2016 12:34 PM
bdp155
Modular V8 (4.6L, 5.4L)
Jan 12, 2011 03:27 PM
dr worm
Feb 11, 2005 04:32 PM
mgriffin
Mar 20, 2002 05:40 PM
stevieray
Sep 18, 2001 05:36 AM
