Neutral Safety Switch?
Old Jan 23, 2012 | 12:46 PM
Bandit91's Avatar
Bandit91
I have a 91 F150 lariat that refuses to start. I had to salvage a new steering column last week, and when i finally had enough time to install it, the truck wouldn't start. It doesn't turn over, but i hear the fuel pump kick on. My dad said something about a "neutral safety switch"... Can someone please tell me what the heck that is or how to fix the problem? Thanks for your help
Old Jan 23, 2012 | 12:54 PM
Hotshot869's Avatar
Hotshot869
The NSS as far as I know is just a switch for automatic transmissions that doesn't allow the truck to start in gear..If you replaced the column, and it's not starting, then something is hooked up wrong or is loose. I'd go back and recheck everything.
Old Jan 23, 2012 | 01:00 PM
octaneforce's Avatar
octaneforce
try to jump the solenoid with a screwdriver
Old Jan 23, 2012 | 01:18 PM
jas88's Avatar
jas88
What transmission does your truck have?
Old Jan 23, 2012 | 01:54 PM
andym's Avatar
andym
The NSS is also used in trucks with manual transmissions. It's on the clutch pedal and won't let you start the truck unless the clutch is all the way in.
However since neither one of those switches are in the steering column, it's probably not the cause. If you hear the fuel pumps running then it's not your inertia switch either. Many people accidentally trip it while working in that area. My guess is that the ignition switch at the base of the column isn't being engaged. There is a rod that passes down the column from the ignition cylinder and that switch is what actually starts the truck, in combination with the NSS.
Old Jan 23, 2012 | 09:36 PM
xxshine's Avatar
xxshine
F.Y.I. The neutral safety switch can be bypassed with no effect on any other circuit. Then one doesn't have to push the clutch in, just to start the motor.
Old Jan 23, 2012 | 09:49 PM
Midnite1987's Avatar
Midnite1987
Can have adverse affects on garage shelving when you accidentally start in reverse with the door open.... Or anything else parked around when you reach in the window to start a standard with it bypassed and dont realize someone put it in gear...
Old Jan 24, 2012 | 08:48 AM
jas88's Avatar
jas88
Depends on the trans. If he has a C6 or an AOD, then it would be on the column.
Justin73supercamper
Oct 15, 2017 12:04 PM
Sportsterengr
Jul 31, 2016 06:33 PM
onewolf1952
Aug 8, 2009 08:53 AM
JEV
Apr 3, 2009 03:15 PM
patsplace
Sep 4, 1999 07:05 PM
