TUNER
Old Jan 22, 2012 | 08:24 PM
BIG-DADDY-F350's Avatar
BIG-DADDY-F350
TUNER
I just finished installing my MBRP" turbo back exhaust today. It sounds great ( no muffler). I have done a 6637 and CCV mod also, and now I'm thinking about a tuner. I drive an early 99 F350,6 speed Trans, SRW ,4x4,CC,Long bed. I'm looking for that extra power for pulling my 35' trailer. Are the most common tuners/programmers useful with a 6 speed manual? I dont see much info out there for the manual trans owners.
Old Jan 22, 2012 | 08:28 PM
joeyd61's Avatar
joeyd61
most people here use DP Tuning (including myself)...You need to get guages first mainly EGT,Trans Temp,Turbo boost....so you can keep your truck safe...
edit---forgot manual trans..probally dont need trans temp,others will chime in
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
yep will be just as useful as an auto......might need to upgrade the clutch later on but itll be a nice purchase for you.....
do your homework before just going with what everyone runs.......there are alot of tuning options out there.....
Old Jan 22, 2012 | 08:31 PM
cutlass's Avatar
cutlass
I have an F5 DP Tuner and I would never think of running any other tuner with my truck. The customer service is top notch as well as the quality of product. They really know what they are doing over there!
Old Jan 22, 2012 | 08:35 PM
BIG-DADDY-F350
Forgot to mention, I have about 250K on this truck. You think I should go ahead with a tuner or are the miles high enough to not bother with the investment?
Old Jan 22, 2012 | 08:40 PM
indyF-350psd
i would get one if you want the extra power......keep in mind you have to pay to play so if you dont want to spend money on anything you might break then dont get one......generally they dont create any problems on a stock to mildly tuned truck.....its when you get crazy big when the expensive stuff starts to happen......
Old Jan 22, 2012 | 08:41 PM
indyF-350psd
they are not the only ones who know how to tune and i used to run dp......not anymore.......
Old Jan 22, 2012 | 08:50 PM
JonathanN's Avatar
JonathanN
I know there are alot of other people who tune, but that's ALL Jody does. Plus, I also like the DP-Tuner interface more than the 6-position rotary **** chips that alot of the others use. That's just me, though... everybody is right on the gauges. You can get away with only an EGT gauge, but I would consider a boost gauge later on. Real good tunes can run your EGT's out the roof pretty easy so you'll need to monitor that. Another useful one to fill in the trio if you want three gauges on your manual (don't need a tranny gauge for a manual) would be a fuel pressure gauge.
Old Jan 22, 2012 | 09:11 PM
BIG-DADDY-F350
Thanks for the info. This will give me alot to chew on before I drop some $$.
Old Jan 22, 2012 | 09:19 PM
JonathanN's Avatar
JonathanN
Haha! Yeah... not cheap stuff here.
Old Jan 22, 2012 | 11:30 PM
Bonanza35's Avatar
Bonanza35
If you tow heavy you mit want to upgrade to the late 99 as far as turbo, spider plenums and all. My neighbor has a 99 6 speed, late model, and he went with banks, to much money, but it made the difference. He pulls 38' tow hauler and needed the tork and power. Gauges, can't say enough on that one. First thing. Also, HPOP for sure on the e99. I like the T500. Talk to Clay on that one.
Chet
Old Jan 23, 2012 | 12:06 PM
kawcrasher's Avatar
kawcrasher
IMHO, This is not a sign of good tunes. Good tunes should not have you watching EGT's like a hawk. Expect when towing and shutting down I don't even look at the pyro anymore. When I got good tunes on my truck my EGT's dropped, even over stock. You just can't hold the go pedal down long enough to to make them rise enough to worry about without a trailer on. If I don't try to run a hotter tune then I should, there is not much to see on the pyro even with a load.
Old Jan 23, 2012 | 12:07 PM
PwerStroke99's Avatar
PwerStroke99
Id recommend DPTuner or Tyrant Diesel, Cale can tune a truck, thats who i am running now.
Old Jan 23, 2012 | 12:10 PM
JonathanN's Avatar
JonathanN
Well, when I said good tunes, I meant tunes that aren't off-the-shelf tunes. More aggressive fueling is available with custom tuning, that's why we need gauges... I can't get the EGT's hot very easy, either. Unless I'm laying on it, I don't see too hot until I'm doing 80+. I also run out of oil really fast so I get alot of smoke and lousy combustion doesn't help EGT's out much, either.
ernsppw
20
Aug 7, 2018 06:45 AM
dothedew192
Oct 4, 2011 07:00 PM
Chuckthetruck
Computer Chips & Tuners
Apr 3, 2008 02:35 PM
f250shopper
Aug 24, 2007 08:23 AM
khendrix
2004 - 2008 F150
Aug 26, 2004 08:48 AM
