FICM issues
Old Feb 4, 2012 | 01:16 PM
sweatthawg913's Avatar
sweatthawg913
Update on my FICM issues: I ended up after changing out the power supply on the FICM and still having no start, checking the oil pressure and having over 500 psi, having to re-flash the computer side of the FICM. Somehow it was wiped out. Now it is running like a champ. I do still have the #7 Glow issue which I plan on fixing soon. Any help on how to do that? I have been told that the connectors often break when changing it out so it is good to change that when you change out the glow plug?
Old Feb 25, 2012 | 01:59 PM
sweatthawg913
Ok guys, I'm at a loss. My truck was running great for about a week and half after changing out the FICM. Now I'm having no luck getting the truck to start. I am only getting 9 volts going into the FICM which the FICM is converting to about 33 volts. Any suggestions on what the problem may be? Oh and I put a new #304 relay in as well because I thought it may be bad and be causing the problem, but no luck!
Old Feb 25, 2012 | 02:19 PM
bpounds's Avatar
bpounds
Where are you reading 9 volts? Is that your battery voltage? Not sure what you mean by "9 volts going into the FICM", but that is way too low.
Old Feb 25, 2012 | 06:21 PM
sweatthawg913
I have a Ford dealership mechanic doing some side work for me since now I am out of my element the further I go along. He hooked a computer up to it to take all the readings and he explained to me that the batteries were fully charged but somehow only 9 volts were making it to the FICM. Not really sure what was meant by it but from what I can gather there may be a short somewhere that was causing volts to be lost between the battery and the FICM. I didn't get a chance to talk to him long to ask anymore questions. He told me he was going to start troubleshooting the electrical, such as the fuse box under the hood and go from there. He said my oil pressure is good and the fuel pressure was good (fuel pump is working). That's all I have at this point until I can ask him some more pointed questions. I just thought I would relay what he told in our brief conversation and see if anyone had any ideas.
Old Feb 25, 2012 | 06:47 PM
bismic's Avatar
bismic
Did he do a load test on the batteries? "Fully charged" doesn't mean anything really .........
Old Feb 25, 2012 | 07:14 PM
sweatthawg913
I assuming he did. I just bought brand new motorcraft batteries with 850 cca about 2 weeks ago, so I am sure that they are in good shape.
Old Feb 25, 2012 | 08:27 PM
bpounds's Avatar
bpounds
I'll be interested in hearing what he finds. Unfortunately, whatever the reason for the 9 volts, your freshly replaced FICM may be toast again. And I have to think that this is somehow related to the original FICM having lost its programming. May have happened again.
Old Feb 25, 2012 | 08:45 PM
bismic's Avatar
bismic
What warranty did you get on the FICM?
Old Feb 25, 2012 | 09:32 PM
sweatthawg913
12 month, 12,000 miles
avking2508
17
Apr 26, 2013 11:19 AM
lhud
Nov 8, 2011 10:18 PM
tom01mxz800
Electrical Systems/Wiring
May 10, 2007 05:34 PM
shanes76
1983 - 2012 Ranger & B-Series
Nov 9, 2006 07:49 AM
Ford_Poor
2004 - 2008 F150
Jul 1, 2006 08:19 PM
