390 timing cover question
Old Jan 22, 2012 | 05:11 PM
1oldtimer's Avatar
1oldtimer
What Bolts on the timing cover go into water passages. I'm trying to start mine after a rebuild and it's leaking from a timing cover bolt next to the water pump. Are just the two bolts next to the water pump the only ones?.
Thanks
Old Jan 22, 2012 | 07:00 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Sounds like a crack.
Josh
Old Jan 22, 2012 | 08:56 PM
1oldtimer's Avatar
1oldtimer
hmm, I pulled the bolt out and coolant came pouring out. I put some rtv around the bolt and put it back in.
Old Jan 22, 2012 | 09:21 PM
Bullitt390's Avatar
Bullitt390
Interesting... Hopefully it doesn't leak into the crankcase
Josh
Old Jan 22, 2012 | 10:08 PM
baddad457's Avatar
baddad457
Put some pipe thread sealer on the bolt and see if that stops it. Someone may have gotten a little too "happy" with the drill press when machining the block.
Old Jan 23, 2012 | 05:29 PM
1oldtimer's Avatar
1oldtimer
I found a bare block picture online and it looks like the hole next to the water pump holes "could" be in a jacket. The one circled was the one that was leaking.
Old Jan 25, 2012 | 04:27 PM
puttster's Avatar
puttster
sorry double post
Old Jan 25, 2012 | 04:30 PM
puttster's Avatar
puttster
Oh yes, absolutely that timing cover bolt goes into the water jacket. You can reach your finger into the water pump opening and feel it (or maybe put a nut on it?). It is the only one that goes through, at least on a 1965 352.
Now in 1968 they made a bigger bolt for the timing pointer and it goes into the block but I don't know if it gets into the water.
Old Feb 10, 2012 | 09:32 PM
1972RedNeck's Avatar
1972RedNeck
On one of our newer 390 blocks (don't have casting numbers but it is a ribbed block) you can feel a hump in casting where the threads are.
Old Feb 10, 2012 | 11:49 PM
puttster's Avatar
puttster
on both sides or just the driver side?
puttster
Old Feb 11, 2012 | 10:16 AM
Bullitt390's Avatar
Bullitt390
I've personally never paid attention to the older pre-65 blocks, but newer ones shouldn't go thru to the jacket.
Either way, I can see slathering those particular bolts with silicone should alleviate any issues with the water jacket.
Seems improper, however, to expect the timing cover paper thin gasket and bolt to hold back 12+ psi coolant pressure from entering into the timing cover and polluting the oil.
Maybe that's why Ford later changed the casting?
Josh
Old Feb 14, 2012 | 11:14 PM
1oldtimer's Avatar
1oldtimer
Everything is holding fine under pressure now.
2.5itim
Sep 14, 2016 08:33 PM
96broncoXlt
1978 - 1996 Big Bronco
30
Jan 8, 2012 05:22 PM
fordguy78
Nov 24, 2008 07:52 AM
ATC_250SX
Mar 11, 2004 05:39 PM
abqengineer1
Apr 7, 2003 03:49 PM
