Leaky timing cover gasket,
Old Mar 11, 2004 | 11:19 AM
ATC_250SX's Avatar
ATC_250SX
Ok on my 87 f-150 351, my timing cover is leaking cooland out the right side (sitting in truck) im wondering if i try to tighten it up will it slow the leak or should i go all out and replace the bugger? any help would be good, thanks, jeremy oh and i also plan on doing a water pump while im that far, at 101,000 i figure it will be worth the 31dollars for a new one.
Old Mar 11, 2004 | 12:09 PM
BandBFord's Avatar
BandBFord
Some (four I think) of the bolts in the timing cover go directly into the water jacket. Simply removing the bolt adding thread sealer and reinstalling the bolt might do the trick.
Old Mar 11, 2004 | 05:39 PM
ATC_250SX's Avatar
ATC_250SX
i tightened the bolts up and presto, no leak? oh well, saved myself a bunch of money
BeholdenZippy
Nov 17, 2016 02:22 PM
Redagain
Oct 2, 2016 06:35 AM
Redagain
Sep 26, 2016 02:28 PM
GuitarJesus
Nov 28, 2015 03:14 PM
1oldtimer
Feb 14, 2012 11:14 PM
