Quieter injectors?
Old Jan 24, 2012 | 07:54 AM
CampSpringsJohn's Avatar
CampSpringsJohn
Originally Posted by CGMKCM
If the O.P.s goal is to reduce engine noise in the truck cab, I have tried 2 stroke oil, FRX, in tank and pre-pump mod and added an Adrenaline HPOP. My engine is very quiet for a 7.3 running stock split shots with 80 and 100hp tunes.
I also added poly tubing to my door seals which made my cab quieter.
Some folks are bed liner coating there valve covers and have stated that quieted things down. Insulating the firewall with sound mat is another option. New injectors can make the engine run quieter.
What is poly tubing?
Old Jan 24, 2012 | 08:01 AM
CGMKCM's Avatar
CGMKCM
I guess I should have said 3/8" clear plastic hose. Military service flashback on calling it poly tubing. In colder climates I would stay away from hose and use use foam or surgical tubing.
Old Jan 24, 2012 | 09:21 AM
CampSpringsJohn
What exactly do you do with it? Is it adding an extra seal in the doors?
Old Jan 24, 2012 | 10:32 AM
CGMKCM's Avatar
CGMKCM
You lace it into the door weather seal. Here is a video.
Door Seal Modification Ford Super Duty - YouTube
Old Jan 24, 2012 | 10:38 AM
CampSpringsJohn
I will have to give that a try!! Thanks!!
binuya
May 11, 2021 12:12 PM
hddave44
Apr 8, 2015 03:37 PM
kaipo
Dec 31, 2006 10:21 AM
89 f350 diesel
Aug 9, 2006 09:59 PM
afrock
1978 - 1996 Big Bronco
Dec 9, 2004 07:19 PM
