Is a 'quieter' engine better?
Old Oct 24, 2010 | 10:46 PM
binuya's Avatar
binuya
I hear so much about doing this or that to get a quieter engine. I run biodiesel and the combustion note is much quieter than pump diesel.But I believe that is due to biodiesels higher cetane. I know noise levels have nothing to do with the injectors since you wouldn't be able to hear the injectors working with all the other engine sounds going on. So is a quieter engine better? If so, why?
Old Oct 25, 2010 | 04:18 AM
ron's power stroke's Avatar
ron's power stroke
a lot of the clatter you hear is injector noise....if you go from splits to single shot that clatter gets a little bit louder at idle...off idle there the same as splits...bio has oil in it...thats why they run a little quiter on bio...the intank and a regulated return will also help quite that down some by keeping the air out of the injectors..
Old Oct 25, 2010 | 12:55 PM
CampSpringsJohn's Avatar
CampSpringsJohn
I agree with Ron. The clatter is the injectors working. In tank mods and/or a regulated return, or even a fuel rail crossover will help quieten the injectors. What all of those systems do is help maintain a constant fuel pressure and help eliminate air in the fuel. Air in the fuel makes the injectors noisy, and it also can cause injector wear. Fuel additives can help with quietening the injectors. The knock you hear however, is the diesel fuel going off in the combustion chambers. Unless of course your engine has mechanical issues.
Old May 11, 2021 | 12:12 PM
msta999's Avatar
msta999
my injectors are quieter once i tip into the throttle a little and my injectors where replaced 2 years ago, i have been using Howes since then.
Blind Driver
Jan 7, 2013 10:46 PM
TN97STROKE
Apr 29, 2008 04:46 PM
griswold
Mar 11, 2005 04:22 PM
afrock
1978 - 1996 Big Bronco
Dec 9, 2004 07:19 PM
