wheelbase question
Old Jan 22, 2012 | 02:25 PM
droff85's Avatar
droff85
wheelbase question
I would like some of you to look on the door jam and see what the wheel base is on a regular cab long bed f250 and also what it is on a crewcab short bed. If some people can do this for me I would really appreciate the info. Or if someone knows this info off the top of their head let me know.
I have an idea about taking a reg cab long bed truck and putting a crewcab on it. I know that I will have to really modify the length of the bed but I dont know if the rear tire would be too close to the cab.
Old Jan 22, 2012 | 03:32 PM
BlueMule's Avatar
BlueMule
regular cab long bed..133
crew cab short bed....152
crew cab long bed.....168
Old Jan 22, 2012 | 11:12 PM
droff85's Avatar
droff85
Thanks. That was what I needed to know.
Old Jan 22, 2012 | 11:52 PM
Midnite1987's Avatar
Midnite1987
extended cab long bed is 155......would be closer to what your looking for if you could find one...
Old Jan 23, 2012 | 12:23 AM
ghanson's Avatar
ghanson
Veteran: Marine Corps
Midnite, if BlueMule's numbers are correct then that's actually longer than the Crew Cab Short box.
The super cab short bed will have the closest wheel base to the regular cab long bed.
Old Jan 23, 2012 | 09:59 AM
droff85's Avatar
droff85
Yeah. I thought that the truck I found was a crew but turns out its an extended cab long bed. That will work better so that I can still have some bed left. One last question. What is the length on an extended cab short bed?
Old Jan 23, 2012 | 10:27 AM
Midnite1987
Extended cab short box 138.8"
Old Jan 23, 2012 | 12:17 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
And for the reg cab short bed?
Old Jan 23, 2012 | 12:33 PM
droff85's Avatar
droff85
Damn iPhone. I tried leaving one post and am trying to edit the first screw up.
Old Jan 23, 2012 | 12:40 PM
droff85's Avatar
droff85
Reg cab short bed is either 116 or 117. I can't remember exactly but I own one.
Old Jan 23, 2012 | 12:43 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Well, thank you and if you can be sure of the correct number let me know.
Edit, I think I found it: 116.8"
Old Jan 23, 2012 | 12:47 PM
droff85's Avatar
droff85
Well since I've got a thread already started what auto trans would a 93 f250 with a n/a 7.3 have? AODE or something else?
Old Jan 23, 2012 | 12:49 PM
droff85's Avatar
droff85
Told you 116 or 117. It all depends on which way you round the numbers. But my door sticker says 117.
Old Jan 23, 2012 | 12:54 PM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
7.3 would either have a C6 or an E4OD, no AOD on larger engines.
Old Jan 23, 2012 | 01:01 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Smile
Okey dokey amigo.
JGraz
Feb 10, 2019 07:31 PM
71ChargerRT
Aug 6, 2007 09:24 PM
ChaseTruck754
Jul 17, 2007 08:46 PM
F-750pickup
Mar 29, 2004 03:50 PM
StephenKnight
Jun 22, 2003 11:28 AM
