Vin # Decode and Pics
Old Nov 10, 2012 | 08:58 AM
  #31
BarnieTrk's Avatar
BarnieTrk
Thumbs up
Originally Posted by DCClark
Carb List# and few other markings:
It looks to me like it's a brand-new!
With a LIST #: 0-8207
It is a carb TYPE: 1460
CFM: 600
STOCK JETTING: (Front) 622, (Rear) plate 134-39
STOCK POWER VALVE: 8.5
Type of Secondaries: Vacuum
I would suspect it will likely perform just fine on a stock-cammed, V-8.
BarnieTrk
Old Nov 10, 2012 | 09:16 AM
  #32
BarnieTrk's Avatar
BarnieTrk
Then possibly go through this holley which I am unsure as to what it is, and learn a little bit about carbs (I've always had fuel injected vehicles).
I hope I can couple them together and make something a little easier to start with a more reliable choke for winter!
I would be inclined NOT to 'go through' this carb, rather I'd just bolt it on and give it whirl!
You're not going to get a carb'd engine to start in cold weather (less than 25*F) as easy as an injected engine will....
I think your #0-8207 Holley has a bi-metal choke mechanism which has a fitting to attach a heat riser tube to it. If it does and you do attach one, then the choke will work better than it would without it.
My best advise regarding cold starting is to have a well-charged battery and HAVE PATIENCE.....pump the acellerator twice, hit the key and once the engine fires up, feather the accelerator while keeping the idle around 1000-1500 rpms. After about about a minute or three, the idle should settle down and idle at 800-1000 rpms, now you can hop out and let it idle / warm a bit more while you scrape the frost off the windows!
BarnieTrk
Old Nov 10, 2012 | 12:12 PM
  #33
66f250's Avatar
66f250
Thanks DCClark. You don't Know if those came stock on F250's, and what years?
Old Nov 11, 2012 | 07:25 AM
  #34
DCClark's Avatar
DCClark
Thanks for the carb info! Once I get around to swapping intakes, I will indeed just try the carb the way it is. If it doesn't work I can always rebuild it then.
I don't know if they ever came stock, but they look like these American Racing (AR62) Outlaw II's : WHEELS | American Racing
The tires seem to be very popular around from mid 80's to 90's.
the_webers_inc
41
Sep 24, 2020 05:56 PM
Grape Nehi
Jul 22, 2015 10:16 AM
Built Ford Tough i
May 17, 2015 04:45 AM
mxer0022
Apr 27, 2015 08:09 PM
94z28
Sep 30, 2011 04:47 AM
