Engine hung up....
Old Jan 21, 2012 | 07:41 PM
broodog's Avatar
broodog
Engine hung up....
Alright, I replaced all 8 injector cups and 2 injectors, buttoned up the valve covers and now my engine won't turn. I went under to try and turn the pulley with a wrench and it would not spin the correct direction. Any ideas? Could the engine be frozen?
Old Jan 21, 2012 | 07:57 PM
fordpride's Avatar
fordpride
It's hydro locked the cylinders have oil in them. Pull the valve covers off and pull the glow plugs and spun the eng.
Old Jan 21, 2012 | 08:20 PM
broodog's Avatar
broodog
Is that going to push out all the oil or am I going to have to tear down the engine?
Old Jan 21, 2012 | 08:27 PM
dougbrown's Avatar
dougbrown
It will push the oil out. Play tails over it. Hope u didn't bend anything. Pull Maxie fuse 22 think it 30 a and it will not start.
Old Jan 21, 2012 | 08:39 PM
fordpride's Avatar
fordpride
Are unplug the CPS.
Old Jan 21, 2012 | 10:20 PM
Talyn's Avatar
Talyn
Unplugging the CPS would work.
Easier to pull the fuse and relays.
Hopefully you didn't keep trying to force it.
Old Jan 22, 2012 | 10:18 AM
Krisx125's Avatar
Krisx125
will, your friggin avatar cracks me up!
Old Jan 22, 2012 | 10:24 AM
redman84's Avatar
redman84
Originally Posted by Krisx125
william, your friggin avatar cracks me up!
Fixed it for ya. He's a little sensitive about that
Old Jan 22, 2012 | 10:28 PM
broodog's Avatar
broodog
Alright well that worked. Now my next issue is it takes about 15 to 20 seconds of cranking to start her up even after running for a hour. Any ideas?
Old Jan 22, 2012 | 10:51 PM
dougbrown's Avatar
dougbrown
Yea mine doing that same after the turbo rebuild. Glad nothing was bent.
Old Jan 22, 2012 | 10:54 PM
bad12jr's Avatar
bad12jr
Gonna take 60 to 80 good miles to get all the air out.
Old Jan 22, 2012 | 11:01 PM
broodog's Avatar
broodog
That leads to my next issue I bought this truck for 200$ knowing I would have a project. Today when I backed it out my clutch was slipping so bad I had to put it in 4 low and baby it back in. Is this usually a bad clutch or a bad master or slave cylinder?
Old Jan 22, 2012 | 11:54 PM
BuckHammer's Avatar
BuckHammer
I would think if your hydraulics were bad, you would have the opposite problem, meaning that you wouldn't be able to get it into gear without shutting the truck off.
Old Jan 23, 2012 | 02:20 AM
glovemeister's Avatar
glovemeister
Your clutch is likely bad.
Old Jan 23, 2012 | 10:50 PM
broodog's Avatar
broodog
I also hear the noise when I rev the engine up to 2000 rpm then let off. Does this change anything?
kyle j
19
Nov 5, 2013 07:19 PM
JT250
Mar 26, 2011 11:26 PM
Zephyrhills Ford
56
Jan 31, 2011 12:10 PM
joeyd61
Sep 11, 2010 07:59 PM
racenitro
16
Apr 30, 2005 11:46 PM
