Removing Cab
Old Jan 21, 2012 | 12:44 PM
khakushia's Avatar
khakushia
Removing Cab
So I am trying to lift off the cab from the frame. Everything is unbolted and disconnected and ready to be removed. The problem is is that its an extended cab and i am a loner in regards to rebuilding the beast. I was looking at getting one of those over head cranes from harbor freight to help make thing easier. The question is where should i lift it from. DO I rig up some kind of strap system to where the cab wholes are. DO i grab if from the top using straps through the windows and around the roof ? Any sugestions would be appreciated
Old Jan 21, 2012 | 12:59 PM
GNR22's Avatar
GNR22
When we swap cabs on trucks we use a skid loader and a tractor with a bucket on it, and put straps through the windows, pick the cab up, and have another guy push the rest of the truck out from under it and set the cab back down. by yourself, I don't think you can really do it safely.
Old Jan 21, 2012 | 03:20 PM
fordka's Avatar
fordka
he can you send me some pics of everything you did to the cab to strip it. i have to take one off a 95 f150. i have somebody that wants to buy it and ive been working on it for over a week and i havent made to much progress becuase i dont know a lot on what to do.
Old Jan 21, 2012 | 07:11 PM
khakushia's Avatar
khakushia
there is no way pictures will do you justice. let me know what you have done already and i can fill you in on how to go about getting the rest done
Old Jan 21, 2012 | 07:42 PM
Thumper19's Avatar
Thumper19
Most definTely need another hand
No wifey or gf?
Old Jan 21, 2012 | 07:54 PM
khakushia's Avatar
khakushia
yeah but she is like a 100 pounds soak and wet there for moral support not much else
Old Jan 21, 2012 | 08:41 PM
deljac's Avatar
deljac
its not that bad, if the box is off, run your strap thru the windows and lift, the front will lift off first. to lift it level run straps over the back of the cab and hook underneath.
Old Jan 21, 2012 | 09:05 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Well I don't know how to do it with out somebody else but if you get one of those Harbor Freight tools you will be good just put a strap around it's windows and all and lift but do it slowly becuase if you go fast you might break something. If you have an engine puller that will go high enough then why don't you do that even if you just get it a bit higher just back it up and you should be good. But make sure you take your time because most of the time when you think you have everyting good and ready to go you don't truck me I had my brothers and buddies over lifting a cab up and a few wires were hanging them up so I had to cut the wires while they stood there holding onto a 1989 F150 cab. Ain't to easy but you can do it by yourself I would think.
Trav
Old Jan 22, 2012 | 07:16 AM
juni88126's Avatar
juni88126
When we did a friends truck we lifted the cab and put 4x4 under the cab. Then set the boards on saw horses and then rolled the frame out from underneath the cab.
ClassicKidNick
Jun 7, 2021 11:31 PM
rangergirl94
37
Apr 12, 2012 04:35 PM
JimG1098
Jul 29, 2011 11:00 AM
tjustice
Jul 12, 2011 07:56 AM
Gaston
1997 - 2003 F150
May 14, 2008 11:44 PM
