steering column help
Old Jan 20, 2012 | 12:26 AM
ricky1's Avatar
ricky1
ok guys my column is bad now i have found one out of a 97 will it fit my 96 model ,also what models will interchange with my 96 i'm thinking 94-97 is that about right
Old Jan 20, 2012 | 05:21 AM
tdcarter72's Avatar
tdcarter72
I am not sure if it will fit or not being from a 97 model, but anything from a 1992-1996 should interchange.
Old Jan 20, 2012 | 06:12 AM
bashby's Avatar
bashby
in 97 the f150 changed and the 250/350 didnt. What is the 97 column out of?
Old Jan 20, 2012 | 06:26 AM
KC92F150's Avatar
KC92F150
Welcome to FTE!
Why are you saying the column is bad?
If the bearings are bad, keep in mind they can be replaced.
https://www.ford-trucks.com/forums/1...ng-column.html
Hope this helps.
Old Jan 20, 2012 | 07:41 AM
ricky1's Avatar
ricky1
hi and that was my first route replacing the bearings but the owner before me ran it so long that it wore the shaft and there is way to much slack even with new bearings and they dont last long
Old Jan 20, 2012 | 07:43 AM
ricky1's Avatar
ricky1
its out of
96 97 98 FORD BRONCO F150 F250 TILT STEERING COLUMN
hope that helps
Old Jan 20, 2012 | 09:15 AM
oldmansimek's Avatar
oldmansimek
If your truck is a 96 the column will fit from a F-150 or bronco up to 96 only and if its from a 250 or 350 97 is the last year
Old Jan 20, 2012 | 03:22 PM
fordka's Avatar
fordka
i hvae one one out of a 95. it doesnt have tilt though. im stripping the cab and so i got to get rid of any cab parts i dont need to keep.
Old Jan 22, 2012 | 12:16 AM
ricky1's Avatar
ricky1
thanks
mine is a f250 so a 97 will fit ok ?
Old Jan 22, 2012 | 12:18 AM
ricky1's Avatar
ricky1
shoot me a pm with a price
thanks
Old Jan 22, 2012 | 08:34 AM
fordka's Avatar
fordka
not really sure how to pm. i dont see where it has it on here. is yours standard or auto. mine is standard and i dont know if they are the same or not and this is an f150. let me know and i will get back to you with a price.
78 PEB
Jul 12, 2016 02:25 PM
17fordguy
Apr 7, 2015 01:23 PM
97f150xlt
1997 - 2003 F150
May 21, 2011 10:18 PM
diesel_hillbilly
Texas Chapter
Jan 21, 2011 06:06 PM
