will a bad CPS throw a code
Old Jan 21, 2012 | 08:43 AM
blrman1962's Avatar
blrman1962
llooking fo help will a bad CPS throw a code truck just dies on the road kind of sputtered and died whe motor will crank and the tach does not even move I put my auto engineuity on it no codes I cant figure it out. I thiought it was gelled up but i cant find that either truck has been plugged in all night and still nothing. just cranks does the CPS fit the senerio. please help
Old Jan 21, 2012 | 08:57 AM
Justin03PSD's Avatar
Justin03PSD
Sometimes yes, sometimes no. I've experienced both. If you have a spare it's easy enough to swap out.
If you suspect a fuel problem open the drain on the bowl and see what you get.
Also could be oil / hpop related.
Old Jan 21, 2012 | 09:13 AM
blrman1962's Avatar
blrman1962
I opened the fuel bowl and there is liquid fuel in the bowl and did a buzz test the injectors sound good I am hoping that it is the CPS
Old Jan 21, 2012 | 10:44 AM
woodnthings's Avatar
woodnthings
With AE on and watching engine RPM, does it show cranking when you try to start it?
Old Jan 21, 2012 | 12:13 PM
blrman1962's Avatar
blrman1962
I have not looked at that yet and if it does ddoes that mean a good CPS and I need to look at other things
Old Jan 21, 2012 | 12:22 PM
woodnthings
If AE shows RPM your CPS may very well be good since that is where the PCM gets it's signal from. Like mentioned before, throw a spare one in and see if it helps.
Sounds to me more like an oil problem or possibly IPR related. This could be a short or something else.
Old Jan 21, 2012 | 12:35 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
This sounds like fuel bowl heater, don't remember what fuse it is on a 99 but on a 2000 it is fuse #30.
Old Jan 21, 2012 | 01:14 PM
PaysonPSD's Avatar
PaysonPSD
If you are not getting a WTS light do as Richard said and check fuse #30 under dash.
Old Jan 22, 2012 | 03:32 PM
blrman1962's Avatar
blrman1962
UPDATE not the fuel bowl I got that one in northern maine last year at 40 below LOL that was a cold walk back it appears that it was the CPS i changed and it took a while be got her to start drove the 30 miles to work no problem. we will see when I go out there to start her up. I was wondering if anyone knows what the hpop discharge pressure should be at idle thanks for all the help
Old Jan 24, 2012 | 02:00 PM
mark3885's Avatar
mark3885
Min 500psi, my 2000 ,usually about 580 at a warmed idle
Whitey Ford
17
Jan 5, 2024 10:47 PM
blrman1962
Mar 8, 2013 04:12 PM
billfishnut
Apr 25, 2010 11:12 AM
DieselCamper01
15
Feb 25, 2009 10:41 PM
FL_BWAB
32
Apr 10, 2007 09:29 PM
