Ignition coils on 5.4
Looking for some opinions and help.. how difficult is it to change coils on my 05 uperduty and would you reccomend motorcraft or what do you know about accel? I changed the plugs about 20000 miles ago and 3 weeks ago took it to the dealer because of a mis under load, was told that i had 2 plugs fouled out and needed to change plugs. Of course I told them I found that hard to believe and only change the 2 bad ones. 3 weeks later and here I am with the same mis. was told it could be ignition coils. Thanks for any and all input.
The COPs are easy to change. Unplug the COP from the wiring harness, remove one bolt and pull the COP out. Reverse the procedure to install the new one. Don't get much more simple. The new COP comes with a new boot.
Buy Motorcraft COPs. You can get them from Rock Auto for under $44 each. Plus you can get a 5% discount code from the sponsor forum. http://www.rockauto.com/
Thank you all very much for the responses. I was having a hard time believing that $25.00 spark plugs were fouling out already after only 20000 miles. I will have to swing into autozone and see which one has the mis or maybe I should part with some of my wife's moldy money and replace them all.....
