P0236
Old Jan 21, 2012 | 05:54 PM
427 fordman's Avatar
427 fordman
Thanks Mike..
Old Jan 23, 2012 | 01:09 PM
strokin'_tatsch's Avatar
strokin'_tatsch
changed my MAP hose this weekend. No difference. It could be that the MAP doesn't make much of a difference unplugged b/c our tuning doesn't use the MAP.. Might get with your tuner and ask him or pull the chip out and then see if there is a difference with and without the MAP
Old Jan 23, 2012 | 01:15 PM
fordpride's Avatar
fordpride
Haha I beat you to it I did that yesterday and still no difference. My chip is going back for ***** to the wall tuning. Glenn is sending me a MAP to try and the whole fuel system is getting cleaned this week.
Sat. I played with it and the code will set anytime I get over 25psi of boost.
Old Jan 23, 2012 | 02:15 PM
strokin'_tatsch
EDIT: I'm dumb. It looks like the P0238 code would be an over boost code. I guess the 236 is a faulty MAP or circuit problem???
Old Jan 23, 2012 | 03:27 PM
fordpride's Avatar
fordpride
I'm gonna try the MAP from Glenn and if that doesn't do it then I'll start testing wires
Old Jan 23, 2012 | 05:06 PM
427 fordman
FWIW
TSB 94-23-15 - 1994-1997 Power Stroke FAQ
Old Jan 23, 2012 | 08:40 PM
fridgeddiesel's Avatar
fridgeddiesel
My truck has ALWAYS given a 0236 code from the day it came off the factory floor. I tried changing MAP sensors 13 or 14 years ago and it didn't make a difference. I just ignore it since the truck has always ran great with that being the only code thrown.
Old Jan 23, 2012 | 10:08 PM
oldbird1965's Avatar
oldbird1965
That's the one I got, F4TZ-9F479-A. The one i sent you Mike had a different part number, its the orginal one I think?
Old Jan 26, 2012 | 08:48 AM
fordpride's Avatar
fordpride
Change the MAP and still get the code.
Before I ask my tuner a dumb ? do y'all think he could turn off the code ?
JethroF250
Oct 8, 2008 11:09 PM
crazymut
Sep 4, 2008 07:26 PM
PSDiesel911
Jun 7, 2008 04:24 PM
SilverBullet131313
Apr 19, 2006 09:18 AM
unluckylow
Apr 16, 2004 12:55 PM
