overboost inhibiter?
Old Sep 3, 2008 | 06:38 PM
crazymut's Avatar
crazymut
Do you need to tee into the map sensor line for the boost gauge or can you tap into the top of the overboost inhibiter.
Old Sep 4, 2008 | 06:15 PM
DieselBeast01's Avatar
DieselBeast01
I teed into the map line because the direction for the OBA said to. If you teed into the other line the one infront of the sensor, the boost gauge may not read as well.
Old Sep 4, 2008 | 06:39 PM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
if you get one of the brv+ boost valves from dieselsite.com you can run your turbo line off of it. it has a fitting for your turbo line....
Old Sep 4, 2008 | 07:26 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
That is far inferior to a MAP regulator.... junk!
