Sorry for this
Old Jan 19, 2012 | 04:15 PM
sunbird79's Avatar
sunbird79
Sorry for this
I know this is going to sound dumb but here it goes. On my F4 as I release the clutch it’s almost all the way out before the truck starts to move. Is this correct? I'm over thinking this I’m sure….I hope... I think …..see what happens.<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Old Jan 19, 2012 | 04:36 PM
raytasch's Avatar
raytasch
Believe Nothing
That is not correct. 1"-1 1/2" is usually considered the free play starting adjustment. I believe a minimum of 1" at around 3000 rpm is the final adjustment on the original type clutch. Adjustment may be different with replacement diaphragm type. Stay tuned, someone will correct me if I am wrong. My manual is out in the shop and I am warm and comfortable by the fire.
Old Jan 19, 2012 | 05:13 PM
critterf1's Avatar
critterf1
Probably needs to be adjusted.
Old Jan 19, 2012 | 05:55 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
Nope, thats not right. Hopefully you can take care of it with some adjustment.
Worst case scenario is that its worn too bad and you'll have to replace the clutch
Good luck
Bobby
edit:....and don't be sorry for asking a question. Thats what this forum is for. We're here to help if we can. There's bound to be someone who has tons of knowledge about F4 clutches.
Old Jan 19, 2012 | 06:20 PM
bobj49f2's Avatar
bobj49f2
According the shop manual, page 137:
The only clutch adjustment required is the clutch pedal free travel adjustment. The specified pedal free travel should be maintained for best operation. The need for a clutch pedal adjustment is indicated when the clutch slips, chatter, grabs, or when transmission gear clashing indicates the clutch will net disengage. The free travel should also be checked and adjusted after new clutch parts have been installed.
To check the clutch pedal free travel, depress the clutch pedal by hand and measure the distance the pedal travels before the beginning of the clutch disengagement is felt.
The free travel limits are 1 1/8- 1 3/8 inches for 10 and 11 inch clutches, and 1 3/8-1 5/8 inches for the 12 inch clutches. If the free travel is not within these limits, adjust the travel as follows:
Remove the clutch pedal to release arm rod clevis pin, then rotate the clevis pin, then retate the clevis until the pedal free travel is within limits. Install the clutch pedal to arm rod clevis pin and the cotter pin.
NOTE: If the clutch pedal free travel adjustment does not eliminate the clutch trouble, it will be necessary to remove the e clutch for repairs.
Old Jan 20, 2012 | 05:17 PM
raytasch's Avatar
raytasch
Believe Nothing
And my shop manual, copyright dated September 1955
Page 129 suggest the final adjustment made at 3000 rpm.
"On all truck clutches, the centrifugal weights at high crankshaft speed will move the release fingers closer to the release bearing and reduce the pedal free travel by as much as 3/4 of an inch. "
"On all trucks the pedal free travel should be checked while the engine is running at approximately 3000 rpm. The pedal free travel under these conditions must be at least 1/2". Readjust if necessary, to obtain at least 1/2" pedal free travel with the engine running at ~3000 rpm.
My words: If you do not have this clearance at shift rpm it may show up as the clutch slipping when shifting gears. An unskilled or unaware driver may not realize the slippage is occurring.
epdukes13
Jul 28, 2012 12:33 PM
crewforce
Aug 14, 2011 08:41 AM
meier63
Aug 7, 2011 10:07 PM
1984F-150_351HO
Dec 9, 2007 12:58 PM
Wheatina
Feb 23, 2007 01:04 AM
