Dynamat?
Old Jan 19, 2012 | 11:13 AM
CharlieLed's Avatar
CharlieLed
Originally Posted by Blue50F-1
Gotta echo charlie's comments there.
However, the site referenced has now been converted as the guy who was searching for the best product apparently decided he could do it better and made his own product which he details here: Sound Deadener Showdown - Your Source for Sound Deadening Products and Information
This is more than just a sticky deadener, but a system much like Charlie described and what I plan to go with in the future...having some background in audio/acoustics this makes much more sense than simply slapping on the dynamat and calling it good.
Peace,
Jim
Jim,
Thanks for posting that link, Don Sambrook is the guy who I have been referring to as the "soundproofing professional" in my post. The only clarification that I would offer is that Don is not making his own products but merely assembling the products that he has found into a mix that meets his design requirements. I few minutes on the phone with Don and you will come away thinking "how dumb could I have been all these years when it comes to soundproofing". He is very knowledgeable and willing to explain how this stuff works and why.
If anyone is interested in learning more about high-end soundproofing I would encourage them to go to Don's "Sound Deadner SHowdown" site and read up about these products. Don hosted a blog on this topic for years where he evaluated products that were offered on the market. He got into the business of selling his "select" line of products becasue he could not find all the features he was looking for in any one line elsewhere. One thing I learned from Don is that if you keep the CCF and MLV as two seperate layers then it is much easier to install. Other products like BoomMat laminate the two together which makes it more difficult to install and makes for more waste.
Old Jan 19, 2012 | 03:35 PM
Blue50F-1's Avatar
Blue50F-1
Originally Posted by CharlieLed
Jim,
Thanks for posting that link, ... Don is not making his own products
Charlie,
No problem. So far as Don making his own products, I got the impression that his CLD Tiles were his own creation.
From his CLD Tile Page: "With this in mind, I set out to create the best constrained layer damper I could. The first step was to develop the adhesive/damping layer. Two years of testing and tweaking went into this phase. I wanted maximum effectiveness and durability as well as solid performance over the widest temperature range possible. I also wanted extreme heat tolerance – in case you need to subject it to that sort of torture and because heat tolerance is a very good predictor of stability over time.
Once I was satisfied with the adhesive I started to test aluminum constraining layers...
Either way, the system is the same, and I have to say that it makes more sense than simply slapping on a dynamat/peel & seal type product and calling that good.
Peace,
Jim
Old Jan 19, 2012 | 08:07 PM
carnut122's Avatar
carnut122
Originally Posted by Jeff and Nicolle
I wondered about putting it in the roof above the headliner...it won't drop?
The Fat Mat that I put above my headliner would take a jack-hammer to get it out. OTOH, it hasn't been out in the hot sun yet.
Old Jan 19, 2012 | 09:32 PM
fifty-two_f1's Avatar
fifty-two_f1
So i am considering using the fatmat since its easier on the wallet. How does this compare to dynamat? I emailed Don about the good stuff and he said it would probably be around 450. Thats a little steep for me. Im not saying its not worth it but dont forget that I am a senior in high school with no job.....
Old Jan 19, 2012 | 09:45 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle
After following this thread, I won't be using lowe's peel and stick! Thanks for the info!
Old Jan 19, 2012 | 11:35 PM
audioguru76's Avatar
audioguru76
I like the comment about "putting images of shiny vehicle interiors out of your mind..."
Even though I know that 100% coverage is WAAAAY overkill I still do it. I may later go back in with some of the CCF and MLV.
Old Jan 20, 2012 | 08:33 AM
HD74's Avatar
HD74
This is my thread on the subject and also check my album with the same title for more pictures. Bottom line is this stuff works great!
https://www.ford-trucks.com/forums/7...d-upgrade.html
Old Jan 20, 2012 | 05:00 PM
rhopper's Avatar
rhopper
I'm using the peel and seal, and have had no problems with it. On the floor, I just peeled the paper and stuck it, but the instructions say to apply when it's 60 degrees or warmer. On vertical surfaces, I added a layer of spray on contact cement to ensure it stays put. Same for the inside of the roof. I've only had my truck out one summer, but there have been no issues with melting or drooping. On the hotrodders website, there is also a thread about an alternative to lizard skin. I made my own lizard skin from info in that thread, and applied several coats to the entire inside of the cab. If you're really worried, buy the peel and seal for the floor, and the spendy stuff for the roof.
Old Jan 20, 2012 | 08:20 PM
carnut122's Avatar
carnut122
I ended up using 75 square feet on mine and could have used another 10. So, 100 square feet should do you. Here's a link:
100 Sq Ft Sound deadener Fatmat no logo Dynamat Roller | eBay
I'm not sure how it compares, but I doubt that Dynamat is over twice as good.
Old Jan 22, 2012 | 11:57 AM
56panelford's Avatar
56panelford
I've been installing Eastwoods thermal accoustic barrier in my panel. It definately makes a difference as far as deadening the sound. I bought it when it was on sale which is quite often for $119.00 a kit that covers 33.75 square feet.There is 9 pieces 18-3/4" x 31".
Old Feb 4, 2012 | 07:28 PM
Blue50F-1's Avatar
Blue50F-1
56Panelford,
FYI: I just sent you a PM with a link to this thread! D'oh!
Old Feb 4, 2012 | 11:21 PM
BACAGrizz's Avatar
BACAGrizz
I used some stuff that was less expensive than DynaMat. It's called Roadblock'r from Soundproof Cow.
Automotive Sound Deadening | Car Sound Deadening - SoundproofCow.com
beartracks
20
Dec 25, 2021 06:07 PM
70torino429
Mar 1, 2011 06:42 PM
RocketMonkey28
Jun 25, 2009 08:37 PM
masterbeavis
Oct 21, 2007 07:23 AM
logan_85
Apr 16, 2001 08:00 PM
