Fan speed switch problem...
Old Jan 17, 2012 | 05:36 PM
jamnjm's Avatar
jamnjm
Question Fan speed switch problem...
1994 e-150 van and the interior fan speed switch only works on HIGH. I remember a thread about a open resistor in the ac / heater box and it was available from Autozone but my search came up empty. Plus AZ counter guys are useless.....
Old Jan 17, 2012 | 05:38 PM
joshofalltrades's Avatar
joshofalltrades
the resistor would be your problem, so go to napa, carquest, or whatever parts store around you has older guys working there
Old Jan 17, 2012 | 05:58 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If they can't find a blower motor resistor they really need to find another job.
Old Jan 18, 2012 | 03:12 AM
wizzy214's Avatar
wizzy214
the fan switch in my van has been replaced a few times. it was the switch itself. that went out. easy find at the wrecking yard.
Old Jan 18, 2012 | 03:04 PM
Club Wagon's Avatar
Club Wagon
Why speculate whether its the "Fan speed switch" or blower motor resistor, when it's so easy to pull/test the resistor?
You can confirm/eliminate the resistor quicker than you can boot up computer & post the Q on FTE.
If not resistor it's a good bet the switch is at fault, but some are discouraged from venturing behind the dash panel b/c of Fear of Spaghetti.
Both switch & resistor are an "easy find at the wrecking yard" but going to a Self Serve wrecking yard may be more satisfying.
Old Jan 19, 2012 | 05:21 AM
JWA's Avatar
JWA
Typically Jamnjm if you have any fan operation at all the dash switch can be considered good---at least for the moment. I've had two of them over heat and melt to the point they stop working but that's not too common a problem. Chances are it is your resistor bridge. NAPA or a better parts outlet---even RockAuto.com or the stealership tend to have more knowledgeable staff as well.
Here's an image that might help you locate this part if you don't already know:
HTH
Old Jan 23, 2012 | 06:21 PM
jinxs's Avatar
jinxs
I have a 99 ford f350 the heater only works on high
I have replace the resistor twice and replaced the fan control switch
can,t figure out why the resistor keep going out
Old Jan 23, 2012 | 06:42 PM
critterf1's Avatar
critterf1
Part# for the resistor is RU1013 from Advance Auto.
Old Jan 24, 2012 | 04:54 AM
JWA's Avatar
JWA
Jinks your situation might be the blower motor drawing too much current for the switch and/or resistor bridge to handle, making them fail but not tripping any fuses etc. If you're using budget friendly parts that too might contribute.
When changing the switch or the resistor do you notice any signs of excessive heat due high amp draw? My '00 E250 lost all but the high fan setting and there was a faint odor of melted plastic too. I discovered the switch had melted internally and its wire harness connector also deformed. Luckily both were available from NAPA and somewhat of an easy installation.
Its highly unusual to go through two switches and resistors so quickly---has to be something else causing this.
jvmcc
Aug 13, 2016 02:38 PM
97-psd
Jun 11, 2008 07:04 AM
tractoman
Mar 30, 2006 10:51 PM
allanhilliard
Aug 24, 2004 10:30 PM
