I have a 2006 F-250 Power Stroke started running rough then motor stoped was able to start it again moved it stoped again want start got a code p0017 camshaft position correlation bank 1 sensor B would this stop it from starting and is it hard to change I have 170000 miles on the truck i'm new to this site would like help Thanks a;lso had other codes p0261,p0264,p0641,p0098
Welcome to FTE
CMP sensors dont normaly fail on these
P0017 Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor B
this one is probably from the stall/no start event we wont worrey about this code just yet
lets go thru the codes
P0261 Cylinder 1 Injector Circuit Low
P0264 Cylinder 2 Injector Circuit Low
P0641 Sensor Reference Voltage "A" Circuit/Open
P0098 C* O R Intake Air Temperature Sensor 2 Circuit High Input EGR disabled, greater than 4.8v MAT signal circuit, open, short to power or defective sensor
with all those codes you need to check the FICM voltage heres the link
