Will a bad Nox sensor cause No Start condition?
Old Dec 23, 2013 | 05:47 PM
erikkloss's Avatar
erikkloss
Does anybody know if a nox sensor will cause a no start condition? I just bought a 2011 that will not start (cranks over ok). I am getting codes U059E and P225A codes for nox sensor. I am curious if these codes will fail safe the computer to not start.
Old Dec 24, 2013 | 08:09 AM
WildWildWest's Avatar
WildWildWest
Bad NOX sensor put my truck into limp mode without a check engine light 18 months ago - didn't have a code reader at the time. The truck could be shut off and started again but remained in limp mode. I don't think it by itself would create a no start condition.
Old Dec 24, 2013 | 08:21 AM
Sqidget's Avatar
Sqidget
The U059e is invalid data from NOX sensor 1
p225a is for internal memory of the NOX sensor. Check the fuses, the codes could be caused by the computer not receiving any data from the sensor,
because it is not on. The same fuse could also power whatever is not allowing it to start.
It is just a place to start, NOX sensors won't usually cause a no start.
Old Dec 24, 2013 | 02:20 PM
erikkloss's Avatar
erikkloss
Okay, thank you everybody. That is what I needed to know. I'll keep on the diagnostic path until I figure it out.
Jerry Chaney
Mar 19, 2014 01:02 PM
moose4x4
Jan 31, 2010 10:06 PM
specialist484
Jun 5, 2007 06:30 AM
Jrock909
Oct 22, 2004 07:45 AM
doc300
Jan 22, 2004 03:05 PM
