bad fuel pump?
Old Jan 15, 2012 | 07:56 PM
coonbottom's Avatar
coonbottom
bad fuel pump?
yesterday i was going down the highway and my truck just randomly shut off going 55mph and wouldnt start back up and the fuel pump wasnt turning on. so could it be just a bad fuel pump or filter is clogged?
Old Jan 16, 2012 | 03:27 PM
subford's Avatar
subford
The fuel pumps will only run for one second each time you turn on the key.
Are you saying that the selected fuel pump will not run for the one second?
Do you have two fuel tanks? If so are you saying neither fuel pump will run for one second?
Bad fuel pump? Maybe, but could be other items as well.
What year is your truck?
What size engine do you have?
Old Jan 16, 2012 | 04:01 PM
coonbottom's Avatar
coonbottom
1990 f150 302 shortbed, so I only have one tank and I can't hear fuel pump turn on for the 2 seconds. When u try to start it all it does is keep cranking over and rpms might reach 200 but won't start
Old Jan 16, 2012 | 05:12 PM
subford's Avatar
subford
Check your Inertia switch by pushing the button down on top of it.
No luck, ground pin #6 of the self-test plug and turn on the key, does the pump run all the time now?
Old Jan 17, 2012 | 11:55 AM
coonbottom's Avatar
coonbottom
Alright thanks, I'm going to look at it tomorrow
sand1
Oct 22, 2016 06:05 AM
wilsonjoey22
Oct 18, 2009 08:15 AM
htcsusn
Jan 3, 2007 06:57 AM
BUSTMUP
Nov 21, 2005 04:26 PM
