oil in the plenum
Old Jan 16, 2012 | 09:12 PM
revans9295's Avatar
revans9295
oil in the plenum
i have a 1990 f-250 4x4 ,351w . i took the plenum off to put a new valve cover gasket on the passenger side and noticed oil in the back hole on the plenum . i know that is where the pcv valve is piped in . but what would make the oil come up in the plenum ? not alot but enough to drip out when i was putting it back on . is this normal ? or is something wrong again .lol
Old Jan 17, 2012 | 12:56 PM
White Max's Avatar
White Max
A little oil isn't abnormal. A lot of oil would be reason to suspect a faulty PCV valve, excessive blowby, etc.
Old Jan 17, 2012 | 02:48 PM
rla2005's Avatar
rla2005
Ford also re-routed the PCV vacuum line to the center vacuum tree around 1994-95ish. They also issued a service bulletin about it. Too much oil has resulted in hydraulic lock. By moving the vacuum source, any sucked in oil is more evenly distributed.
Check/replace your PCV, re-route your vacuum source line. Also make sure the fresh air supply hose is properly routed to the airbox. There is a filter in there below the main air filter for the engine.
1985-f250
Jan 24, 2014 10:08 AM
BRay09
Jan 21, 2011 07:25 AM
TxFireFghter
1978 - 1996 Big Bronco
Jun 21, 2010 10:28 AM
mpippins
May 5, 2004 01:53 PM
mamafedmepaintchips
Jan 3, 2004 12:35 PM
