Minor electrical problem..quickly becoming dangerous
Old Jan 14, 2012 | 08:59 AM
Kommandant's Avatar
Kommandant
My truck has had a strange electrical issue in the steering column since I got it. Basically when the key is turned the starter doesnt engage till you got the key turned to start as far as you possibly can.. then if you accidently bump it at all back towards off it kills the engine. The deadly part of this is my truck keeps cutting off when I hit bumps in the road and then I have no brake pressure to stop.
I dont know if its related ( but it seems to be ).. my wipers only turn on if I wiggle the key and/or entire steering column while its running or hold it slightly forward.
Anyone have a clue as to what is going on? Seems to me the accessory power isnt getting engaged.
Thanks guys
1990 F350 4x4 351
Old Jan 14, 2012 | 09:02 AM
Jaime74656's Avatar
Jaime74656
have you torn into the column yet? could be loose connector somewhere or pinched wire(s)....bad switch too? just what it sounds like it could be to me...
Old Jan 14, 2012 | 09:15 AM
Kommandant's Avatar
Kommandant
I havent torn into the column. Right now its my only transportation to work and if I miss a day I'll likely get fired so Im reluctant to go poking around inside without a general idea of what it could be
Old Jan 14, 2012 | 09:16 AM
4601ton's Avatar
4601ton
Sounds like one of two things to me. Either the actuation rod is bent, making it to where you have to turn the key further to engage the starter...also, the "bent" rod would effectively shorten the distance between the ignition key switch and the physical ignition switch, making it turn it back off a lot easier, especially being that it no longer has the length to fully engage it in the "on/run" position.
The other thing I would think is just a worn out ignition switch...either way, you need to look into your column and see what you, uhm, see...lol
Good luck bud!
Old Jan 14, 2012 | 09:31 AM
Jaime74656's Avatar
Jaime74656
I know the feeling, thats why im considering getting a cheap beater stang (hey I want nothing but a Ford in my name....if I can help it ) so that way if my truck breaks I can have it down to be fixed and not miss work...
Old Jan 14, 2012 | 09:48 AM
rikard's Avatar
rikard
Your power brakes should have enough reserve that you have a couple of power assisted stops even after the engine dies. If this is not the case check your booster system for leaks.
If you can't afford down time you could always get a same year column from a JY. Make sure it works and its tight, this era columns have many issues.
Regards
rikard
Old Jan 14, 2012 | 10:38 AM
tjc transport's Avatar
tjc transport
i ain't rite
sounds like the ignition switch on the lower part of the column has separated.
you most likely need a new ignition switch.
Old Jan 14, 2012 | 12:07 PM
Kommandant's Avatar
Kommandant
Thanks for your replies gentlemen, I at least have an idea of what to look for now.
As for the brakes, they are almost useless once power is cut from the truck. I notice I lose pressure at stoplights too, if I release the pedal and push it down again I have pressure. I'll have to add that to my list of things to check..
Even though these are critical things...its January in Montana and I have no garage to work in. Old man winter isnt exactly motivating me to go tinker hehe. Im broke right now so my spare car is on two wheels and driven by calories. Cheaper than gas but 8 miles one way to work on a 60+mph highway sounds like a recipe for disaster.
Thanks again folks!
Old Jan 14, 2012 | 02:19 PM
rikard's Avatar
rikard
My 83 F150 vacuum brake booster acted the same way for about a month before it started hissing from under the dash. I was hoping that a Ford Cobra 302 was under hood but it was the same old 180k mile tried and true 302 so I replaced the brake booster. Most buy new but others have bought bone yard ones. On our trucks it can be replaced without having to disturb the hydraulic system.
regards
rikard
Old Jan 14, 2012 | 04:44 PM
88n94's Avatar
88n94
Thanks guys
1990 F350 4x4 351
It sounds like a fairly easy fix. Remove the 2 or 4 screws holding the plastic shroud around your steering column below the steering wheel. These screws are accessible from the very bottom side. Phillips head I believe. Find the actual electrical part of the ignition switch, below the actuator rod, which is below the key tumbler. Once you locate the switch loosen the screws holding it and slide it to get the proper adjustment. I think this will solve that problem. If that doesn't work you will have to replace the switch.
Old Jan 14, 2012 | 07:32 PM
Kommandant's Avatar
Kommandant
Come to think of it rikard I do hear hissing for a few seconds after I shut the beast off! Never really thought anything of it till now.
88n94, that plastic shroud you mentioned is loose.. making me think the previous owner was in there poking around. Judging by his other "handi work" Im in for a load of fun. The guy was splice-happy. I see wires spliced to other wires that connect to nothing haha.
Old Jan 14, 2012 | 08:01 PM
Jaime74656's Avatar
Jaime74656
uh oh...splice happy owners are never good ...what ever the fix keep us posted on your progress
Old Jan 14, 2012 | 09:49 PM
Kommandant's Avatar
Kommandant
I dont understand the previous owner. He took the time to put this F350 on a F450 frame, bore-over the engine, put F550 springs and a F550 axle on it.. give it a lift, aluminum rims and nice oversized 10 ply all terrains.
But he splices wires all over the place, used gasket maker for the rear output shaft on the transfer case (leaks), spray painted the interior and exterior and hooked the stereo up incorrectly ( bad ground?) so it shuts off when you turn on the lights.
With that being said I love the old beast... except for when I visit the gas station.
It doesnt look too big in the photo but consider the top of the picnic table is about level with the rocker-panels
Old Jan 15, 2012 | 08:33 AM
rikard's Avatar
rikard
X2 on Jaimes "uh oh". I have had two vehicles that had splices and all kinds of questionable adapters. On both I essentially ripped out all of the splices, scotch lock connectors, all of the added wire and anything else that wasn't factory. Fortunately my job as an HVAC/R mechanic involves wiring so I had most of the tools and knowledge.
Get the right tools -
1) A good solderless connector set that will allow you to make good connections, about $40-$75
2) A DMM (Digital Multimeter) will help unlock the mysteries and keep the smoke in the wires. I like the auto ranging ones with big numbers. Between $40-$100.
3) Non standard wiring is dangerous and confusing. Get rid of any wire or connector that isn't made for a vehicle like solid wire or lamp cord. Wire designed for vehicle use is stranded and is resistant to oil and gas.
4) The Haynes manual has a good diagnostic section and some wiring diagrams.
Sorry old man rambling
GO PATS
rikard
Old Jan 15, 2012 | 08:51 AM
joendoodle's Avatar
joendoodle
Several years ago my 82 years old MOM's Taurus developed similar symptoms...
I bought her a new ignition switch, took about 20 minutes to replace although I don't remember all the details, except you do need the original key to remove the old one....
Only negative that came out of this, she now had 1 key for the doors and another for the ignition...
hey that's thay way Fords used to be anyway..
irfreddy
37
Jul 20, 2016 12:53 PM
Ranger Gord
1997 - 2003 F150
Dec 9, 2012 05:13 PM
zswiss182
Jan 27, 2010 09:27 AM
Smurf-Slayer
1983 - 2012 Ranger & B-Series
Jun 12, 2006 08:46 AM
sedel
Nov 7, 2004 04:16 PM
