urgent! ignition stuck ON/AUX psoition even with the key out
need help quickly on this. went to leave work and it was hard to turn then popped to ON and from then on OFF-AUX-ON are all ON, turns very smoothly. 2nd AUX(counterclockwise) acts like normal. START acts like normal.
i can put it on OFF and take the key out and the engine is still running.
had to pull the fuel pump fuse to turn it off.
NEW autozone cylinder&key and its doing the same thing.
what else is it???
what else is it???
PDF sent. (that was fast...)
I don't know if Autozone will have the actuator parts.
If you pull the actual ignition switch off, then turn the key while looking at where the ignition switch mounts, you should see the plastic piece moving that slides the pin on the ignition switch. If it doesn't move with the key, the actuator is broke...
removed the switch.
i dont have a tab. i have a slit with a plastic bar inside and a hole in it. hole slides all the way down for crank, positioned at a notch in the metal for ON. and the OFF to ACC doesnt seem to change the slots position. it stays 3/4 of the way towards the steering wheel for both. AUX doesnt move it either.
