leveling kit compatibility
Old Jan 13, 2012 | 06:27 PM
turbill's Avatar
turbill
I found a smokin deal on a 2.5 inch leveling kit for my truck but i want to make sure it will work before i buy
I have an 85 diesel f-250 with the ttb 50 up front
the kit is for 85-Blah f-250 gasser with the ttb 50
the whole deal is for drop down steering arm. add a leaf and the drop down bracket for the arms to insure tire camber. so it should keep tire wear in check i just want to make sure that the whole gasser/diesel part wont cause any differences
Old Jan 13, 2012 | 07:42 PM
Aune163rd's Avatar
Aune163rd
I would assume so because they are both F-250's with the Dana 50.
Old Jan 13, 2012 | 09:06 PM
tecgod13's Avatar
tecgod13
I'll second the probably yes.
The drop brackets for the TTB will be the important part. The add-a-leaf might not have as much effect due to the heavier diesel engine, but I don't think that would be a big difference. Also, if the springs don't quite do enough, you could add in another, or a different spring cheaply.
The drop pitman arm should also be fine, as the only difference in the steering between a gasser and diesel (of the same other specs) would be the bracket to mount the pump to the engine.
Old Jan 14, 2012 | 09:10 AM
turbill's Avatar
turbill
ok i figured that was the case I"M PUMPED
BigBlackF-250
Feb 10, 2016 12:51 AM
SnuffthePunkz
Jul 27, 2014 08:11 PM
Mikes92F250
Mar 13, 2012 10:37 PM
rangerrick63
Dec 16, 2009 08:15 PM
gonegulfin
Jan 29, 2003 01:17 PM
