****LEVELING KIT HELP****
Old Mar 8, 2012 | 11:45 AM
Mikes92F250's Avatar
Mikes92F250
I recently purchased a Rough Country leveling kit for my '92 F250, aka add-a -leaf. The web site said I should gain 2 to 3 inches on the front. I installed the passanger side this morning, it took much longer to install than I thought it would, about 2.5hrs. As of now the pass. side is about 2 to 2.5 inches higher. I plan on getting the truck an alignment with in the next week or two to correct anything that I may have knock out of wack. My question is, will it be necessary to install a drop pitman arm? I did research about the ride of the (add a leaf) springs, but forgot to check for info on the streering. Any help would be greatly appreciated!!! Thanks, Mike
Old Mar 8, 2012 | 12:41 PM
Blue Rebel's Avatar
Blue Rebel
For only that amount of lift you should be fine. Your right at the limit though, any more and i would recommend one.
Old Mar 13, 2012 | 10:37 PM
Mikes92F250
pitman arm
If I did get a drop pitman arm, is there a brand thats better than the rest?
adamysr
Dec 20, 2012 05:54 PM
ganzey
Feb 5, 2011 12:15 AM
SteveOz
Oct 3, 2007 10:55 AM
hc130flyboy
Feb 13, 2005 10:42 AM
