The pyro on my turbo (ATS on an '86 6.9 IDI) doesn't do a thing. The gauge on the steering column doesn't seem to have any connections other than from the pyrometer itself and two wires for a light (which also doesn't work) ...
What's more likely, that the pyrometer has failed or that the gauge is malfunctioning?
And where do you guys recommend I get replacements from?
most of the time(99.5%)when the pyrometer dies it is a bad thermocouple.
you need to match the thermocouple to the gauge.
it depends on what gauge you have.
i have a banks setup in my 88, and as such got the thermocouple from banks when it died.
My thermocouple is dead i believe, havent tested it just yet. but i had gotten ahold of banks via email and told them about it, and they told me i couldnt just get the thermocouple, that i would have to buy a whole new pyro kit. Do you happen to have a part number for the gauge and thermocouple? both would be nice if its not a pain.
Here is a link I found for thermo couples. I can find others but have to get home first. Can't remeber brand I use, I had to replace it. I found part number on manufaturer's web site, then found thermo couple on google for 1/2 that price. http://www.ocdiesel.com/Diesel-EGT-P...Kits-s/914.htm
