which in-line fuel filter
Old Jan 13, 2012 | 12:43 PM
srqdiesel chef's Avatar
srqdiesel chef
got the air leak figured out and now I want to install an in line filter before the electric lift pump. what is a good one to use?
Old Jan 13, 2012 | 12:51 PM
1bigjoe's Avatar
1bigjoe
i like the glass one with the replaceable filters. this way i can see if its cloged or if there are bubbles
Old Jan 13, 2012 | 01:50 PM
Marianna2003's Avatar
Marianna2003
Do you have a Model # or manufacturer? Picture would be nice too.
PS:
If you just want a prefilter for the EP and plan on retaining the OE filter, I like the Fram HPK2
http://www.oreillyauto.com/site/c/de...0538&ppt=C0119
It uses a standard oil filter that is really cheap and should last forever as long as you buy decent fuel.
Old Jan 14, 2012 | 06:42 AM
srqdiesel chef
thanks, Marianna, where did you mount it, would frame rail by the FSV work?
Old Jan 14, 2012 | 12:35 PM
Marianna2003
I would mount it on the frame infront of the FSS so it filters after the FFS.
PS:
OK, I went out and looked at my 92 frame around the FFS. I would mount the filter inside the frame on it's side. The bad part about that is when you go to change the filter, you'll spill a lot of fuel. There are alot of holes in the frame you could use to mount it on outside of the frame. That way you can change the filter without losing a lot of fuel. It is a lot more exposed to foreign object damage. I guess it's your call, just giving my 2¢.
Old Jan 14, 2012 | 04:25 PM
monte97z's Avatar
monte97z
Before my e- pump I used one of those cheapo 3 dollar inline plastic ones. Its clear so I can see fuel.flow and how much junk is in it. Also I installed a 1/4 turn ball valve before it so I can kill the flow of fuel so when I change it I dont get covered in diesel. Just another option for u. Its held up good so far got a few thousand miles on it and its still pretty clean
Old Jan 14, 2012 | 07:16 PM
Crazy2's Avatar
Crazy2
Here a system ill put on my last truck wich was 6.5 chevy it fit nice on frame rail got it at walmart for 28.99 and it came with filter and has in and out port on both ends so won't have bend any lines and all have do plug off the 2 opening you don't need
Fuel/Water Separator & Canister
Old Mar 31, 2012 | 11:22 AM
srqdiesel chef
moved to right thread
StewB
Nov 17, 2025 04:32 PM
cbr600rx7
Dec 30, 2012 11:22 AM
turboner
Sep 13, 2010 12:57 PM
n20
Oct 13, 2009 12:17 PM
QRFleader
1983 - 2012 Ranger & B-Series
Feb 26, 2004 09:06 AM
