Sponsored by: Real Truck
6.2 fuel filter?
Old Jun 22, 2015 | 08:51 PM
StewB's Avatar
StewB
6.2 fuel filter?
I have a 2011 f350 with a 6.2, I can't find any info on a fuel filter for this truck. Is there a fuel filter on it?, or just one in the tank on the pump?
Thanks for any input
Old Jun 22, 2015 | 09:08 PM
eazmo's Avatar
eazmo
I do believe its just the sock on the pump. No changeable filter.
I don't agree with this logic??? money saving not sure the reason
Old Jun 22, 2015 | 10:47 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Napa part #fil3615. Outch $114 for pair.
Old Jun 22, 2015 | 11:47 PM
dkf's Avatar
dkf
^^^^^Isn't that the 6.7l filter?
Looks like a "Lifetime Fuel Filter" on the 6.2l, aka Ford wanted to save a few bucks. When I change a fuel filter I like to shake them up good with the fuel inside and dump them out in a clear container.(dump out the inlet) even with as little as 10k miles through a filter the amount of real fine dirt is surprising.
https://www.ford-trucks.com/forums/1...l-filters.html
Old Jun 22, 2015 | 11:56 PM
DCP's Avatar
DCP
My understanding is, the fuel filter on a 6.2L is a life-time non-serviceable filter that is permanently sealed into the fuel tank according to my owners manual. And, the only way to get a new fuel filter, is to buy a new fuel tank.
Old Jun 23, 2015 | 08:19 AM
MisterCMK's Avatar
MisterCMK
I don't see a problem with the in tank filter....
Old Jun 23, 2015 | 08:35 AM
phillips91's Avatar
phillips91
6.2 fuel filter?
Can't say I'm a fan of that design either. Even if it will last a lifetime I prefer easy access and the ability to replace it cheaply.
Old Jun 23, 2015 | 11:59 AM
don123's Avatar
don123
I don't like the idea of that. I guess time will tell!
Old Jun 23, 2015 | 12:57 PM
MisterCMK's Avatar
MisterCMK
6.2 fuel filter?
There is no need to replace the tank filters. Your pump is going to fail before the filter plugs up
Old Jun 23, 2015 | 01:01 PM
MisterCMK's Avatar
MisterCMK
6.2 fuel filter?
That's like saying you want easy access to replace the connecting rods....
Old Nov 16, 2025 | 11:39 PM
mikekerr's Avatar
mikekerr
A few years ago I purchased a 2015 F350 supercab with the 6.2L engine. I am the second owner.
The previous owner installed a Ford OEM in-line fuel filter, the same filter I have on my 2002 F350 with the 6.8L V10.
No idea why the previous owner installed an OEM external fuel filter on the 2015 F350, but he did, and I change the filter on occasion.
Old Nov 17, 2025 | 07:56 AM
2015 F-350's Avatar
2015 F-350
This filter?
https://ford.oempartsonline.com/oem-...ter-2m5z9155ca
Looks like FORD uses this filter on a lot of different engines, up to the 6.8L
Old Nov 17, 2025 | 04:32 PM
mikekerr's Avatar
mikekerr
Yes, that is the filter the original owner installed.
bflora
28
Mar 26, 2014 06:01 PM
61 uni
Nov 22, 2008 08:20 AM
mattpowerstroker
Jan 16, 2008 07:43 PM
frigerator
Apr 18, 2004 11:09 AM
