Ford Explorer as donor for 54 panel
Has anyone used the front and rear suspension from a Ford Explorer under a 53-56 F-100. I have seen some comments about using the rear, but never the front suspension. As opposed to the Crown Vic, the track seems to be closer to the F-100 and would eliminate tire/wheel issues. I'm also thinking about using a 2002-2005 with the independent rear suspension.
I have no problem with fuel injection and the electronics and am also considering using the engine. I know there are limited after-market mods available, but I think I can live with that.
Any comments? Thanks in advance.
What does that make it?
I wonder about doing that also. I'm not sure what DMV would do with it. Is is a '99 with a trick body or a '52 on a new frame. I think in some states that will make a difference with emissions and such
Just not sure what will work. I want to build a truck that is confortable for long hauls and could handle well enough as a daily driver in city traffic. If there's one vehicletht I could use for front adn rear suspension and the drivetrain, that would be easiest I think. Is there a magic car that will work for that?
Title it as 54,there should be a # on the body . Some states will want the body number and the new frame number. Since the states treat it different,i would check with the local D.M.V . Myself in the state i live in if i had a title for the 54 ,that's how i would title it. Best to check your own area D.M.V. though.
nairod
09-02-2016 05:06 PM
robbyriot
Ford Truck Parts for Sale
04-20-2016 11:29 PM
nice59fordf100
10-31-2010 03:30 PM
