99 F250 Odometer Prob
Old Jan 10, 2012 | 07:35 AM
Engalwood's Avatar
Engalwood
We have had this prob for a while now. Just now thought to ask you guys what you thought. Odometer doesnt work on the truck unless you hit between 30-40 MPH. Everything else is working out fine besides the MPH dial... And like I siad it only engages when you hit 30-40 MPH. Would this mean this is going out are would it be a sensor problem?? Thanks guys
Old Jan 10, 2012 | 11:52 AM
John7894's Avatar
John7894
Clean the speed sensor on the top of the rearend first. Pull it out and it probably has some fine metal "dust" stuck on it. Clean it up and stick it back in. Check all the wiring connections under the truck too.
Might just need a new speed sensor.
Old Jan 10, 2012 | 12:06 PM
Engalwood's Avatar
Engalwood
Weres the resend located?
Old Jan 10, 2012 | 12:17 PM
John7894's Avatar
John7894
On top of the rear end. Straight above the pinion. Can't miss it. One bolt holds it in and it pulls straight up and out.
Old Jan 10, 2012 | 01:56 PM
Engalwood's Avatar
Engalwood
So how would I know if its the spped sensor?
Old Jan 10, 2012 | 03:25 PM
John7894's Avatar
John7894
Clean it and see if the problem gets better. It could also be the speedo itself in the dash. It's all fed off the VSS signal that is made by the speed sensor.
I had an old F150 that had a bad speedo cluster.
Old Jan 10, 2012 | 05:14 PM
Engalwood's Avatar
Engalwood
Cleaned it. Ordered new one. Be here tomorrow. It was covered n metal gunk. If that doesn't fix it does that mean I need a new cluster, are speed cluster like you said. I have no idea when it comes to items like this... I dont know if it matter but I didn't tell u that, the actual mileage maker it self only works past 30-40 mph as well. Should of said that too. My bad... Kudos
maverick1701
Oct 6, 2008 09:33 PM
RangerPilot
Mar 5, 2007 05:17 PM
clintbonnie
Oct 5, 2005 11:39 AM
roddoggy
1983 - 2012 Ranger & B-Series
Mar 14, 2004 08:33 PM
unclematty
Jan 2, 2004 12:02 AM
