No Heat
Old Jan 9, 2012 | 04:28 PM
kpbankey's Avatar
kpbankey
No Heat
I have a 2005 F-350 6.0 with climate control and the heat seems not to be very warm at all. The truck runs at normal operating temp also. I drive 20 miles to work 1 way and I have it cranked up on 90 degrees and I never get hot. The fan blows on high speed, and little heat blows out just not hot heat. My past Ford trucks have heated me outa the cab and this one wont. Any suggestions?????
Old Jan 9, 2012 | 04:51 PM
PA-Mark's Avatar
PA-Mark
need more info
firs off keep in mind that with the limited info and assuming a few things, I think the blend door for the temp mix is not operating.
But what would help us all here in helping you is...
has the heat ever worked, or is this a new to you truck?
Is the engine temp getting up to proper level, You didnt mention.
I say this from experience, I drove my truck during the summer with the t-stats stuck open and i didnt notice right away, so make sure the engine temp is normal.
Like i said thow, I think it may be the blend doors, im not am expert at these doors and thier oreration, but some one here is, just add the additional info and be patient... they will chime in
Old Jan 9, 2012 | 09:40 PM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Powerstroke Diesel forum.
Old Jan 9, 2012 | 09:54 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
I agree, a bit more information would help. Have you confirmed that you have full function of your blend door/actuator. When turned to the cold position do you have cold air? Can you hear the pitch of the air change when changing it back over to hot? There is also a valve under the hood (passenger side) that has a gray vacuum hose going to it. Sometimes that line falls off.
I just changed out a heater core on a 2002 F150 that was completed rusted up. I was able to tell by bringing the truck to operating temp with the heater on, then grab both hoses. One was noticeably hotter than the other... Once removing it I flushed it out and got all kinds of rust and chunks out of it. You may try to flush the heater core out with a water hose both directions to ensure your core isn't clogged up.
Hope that helps a little...
Old Jan 9, 2012 | 10:00 PM
Maxium4x4's Avatar
Maxium4x4
Check the in line shut off valve and see if it is working, maybe the vacuum hose that actuates it is off. Passenger side of the engine.
Old Jan 10, 2012 | 05:35 AM
npccpartsman's Avatar
npccpartsman
You need to check that the truck is getting up to actual operating temperature, not just what is showing on the indash idiot gauge. The thermostat's on these trucks seem to have a "high" failure rate (stick open) and despite what the dash gauge says they don't get hot enough. Cold is BAD on a diesel's efficiency.
Old Jan 10, 2012 | 06:14 PM
kpbankey's Avatar
kpbankey
When Im driving the engine temp runs 180-190 according to my Hypermax chip, and when I adjust from cold to hot air the air temp does change and there is a change in sound from fan, but the hot side is luke warm, not hot
Old Jan 10, 2012 | 07:12 PM
9228.bobcat's Avatar
9228.bobcat
Check coolant level
cobrar97
1997 - 2003 F150
Nov 12, 2008 09:42 PM
Zero Obliquity
15
Sep 22, 2007 02:19 PM
97explorerguy
1997 - 2003 F150
Feb 15, 2007 08:22 AM
atterz8170
Feb 7, 2007 07:50 AM
Jimbo302
Jul 16, 2003 08:50 PM
