MSD problem
Old Jan 8, 2012 | 12:19 PM
greekpilot767's Avatar
greekpilot767
MSD problem
Hi everyone,
I have an F700 with a 429 gas. I removed the factory distributor (it cracked) and replaced it with an HEI conversion that works awesome. I just installed an MSD 6a and don't have a tach now. Any tips would be great. Before I spend 70 for a tach adaptor.
Alex
Old Jan 8, 2012 | 03:42 PM
Franklin2's Avatar
Franklin2
The instructions say you need adapter 8910 for it to work. MSD Ignition Instruction Download
Old Jan 9, 2012 | 01:44 PM
critterf1's Avatar
critterf1
This is a "have to have it"
Old Jan 9, 2012 | 06:19 PM
Franklin2's Avatar
Franklin2
I can only go by what the instructions say. These MSD ignitions are capacitve discharge and actually "push" the voltage into the coil. For that reason you can't use the coil connection like the original tach used. They give you a special "tach" connection on the box. Why doesn't it work without a adapter, I do not know. I suppose you have the option of buying the adapter, or buying a aftermarket tach that works with the "tach" connection(a few tachs do work with it).
byro01
19
Jul 3, 2009 11:41 AM
galaxie641
Modular V8 (4.6L, 5.4L)
Jul 31, 2008 08:32 AM
smallblock351w
Apr 5, 2006 05:48 AM
Zed
Aug 27, 2002 02:39 PM
weldman
Aug 22, 2002 11:02 AM
