MSD 6A work with tach?
Old Aug 21, 2002 | 11:21 PM
weldman's Avatar
weldman
Well, I'm about to make the MSD plunge and buy a 6A and blaster 2. One question, will my autometer 2 5/8 tach work with the 6A's multi-spark stuff?
Thanks!
Old Aug 22, 2002 | 12:49 AM
gray79f250's Avatar
gray79f250
I dont see why not itll still hook to the coil.
Old Aug 22, 2002 | 06:08 AM
flatliner's Avatar
flatliner
I have a MSD 6T and it has a connection just for the tach. It doesn't hook to the coil anymore.
Old Aug 22, 2002 | 07:43 AM
weldman's Avatar
weldman
[updated:LAST EDITED ON 22-Aug-02 AT 08:48 AM (EST)]Doh! Your right! I just looked at the online istall instructions and the 6A is labelled as having a tach output!
Thanks for putting my mind at ease!
My ignition module has really been acting up lately, so I can't wait to put in the 6A!
Thanks again,
Matt
EDIT- Where did you mount your 6T? In the stock location? I figured that would be easiest/look the best. It is a long trip to the battery from there though. Did you take your ground right to the battery per the instructions?
Old Aug 22, 2002 | 07:46 AM
FE427TP's Avatar
FE427TP
DO NOT HOOK MSD IGNITION TO THE COIL
20 sparks per cylinder*3000RPM= makes your tach think the engine is spinning 60,000RPM they have a special hookup for using a tach . I just ran a wire under the back lip of the cowl from the box across to a hole in the firewall for access to the cab (see sig pic)
Old Aug 22, 2002 | 08:56 AM
TorqueKing's Avatar
TorqueKing
Yeah, and the MSD will actually work will more tachs than it says it will. I have a Sunpro gage, MSD says it needs an adapter, but it works great plugged in to the tach output. I've checked it with several other devices, and it's extremely accurate.
'77 F100, 302 (the aftermarket Prodigy), C4
Cadet Second Lieutenant John F. Daly III
South Carolina Corps of Cadets, The Citadel
The TorqueKing
Old Aug 22, 2002 | 11:02 AM
wildebeast's Avatar
wildebeast
