factory tach doesnt work since installing msd ignition.
Old Apr 4, 2006 | 05:14 PM
smallblock351w's Avatar
smallblock351w
I have a 1980 ford f 150 4x4 and i changed the ignition over to msd. Wonder how to hook it up so the factory tach will work?
Old Apr 4, 2006 | 07:17 PM
Franklin2's Avatar
Franklin2
If you look in your instructions on page 7, they tell you if the special tach terminal on the msd unit will not operate your tach correctly, then you need to get a tach adapter #8910 or #8920, depending on how you hooked the box up.
Old Apr 4, 2006 | 07:26 PM
smallblock351w
okay well atm im not really sure what to hook to to get the factory tach to work.
Old Apr 4, 2006 | 07:32 PM
Franklin2's Avatar
Franklin2
I don't have my diagrams with me, but I think it should have been a wire that hooked to the negative of the coil in the old system. It may have branched off at the old ford ignition box. Have any wires left over hanging after the new install?
Old Apr 4, 2006 | 08:11 PM
OneSweet81's Avatar
OneSweet81
don't know if this helps but i installed msd box and distrubor and coil and my stock tach works great
Old Apr 5, 2006 | 05:48 AM
pknute's Avatar
pknute
I have a 1980 F350 400 with a Crane ignition - distributor, module and coil - and I suspect that the tach wiring for the MSD is probably the same. The green wire that used to connect to the coil neg should be connected to the MSD tach feed wire. Then locate the black with green dot wire that used to go from the Duraspark module to the duraspark distributor ground and make sure that wire is grounded to the frame or wherever you choose. The combination of the MSD tach feed to the green tach wire and the black with green dot wire to ground completes the tach circuit.
rowdyredneck
Aug 3, 2013 10:45 AM
bruno2
Feb 21, 2012 10:00 PM
Old Hickory
Feb 26, 2011 08:39 AM
mshumack
Oct 18, 2002 08:02 PM
GendoIkari69
15
Apr 28, 2002 07:05 AM
