Need some pistons, having trouble
Old Jan 6, 2012 | 05:18 PM
RIKIL's Avatar
RIKIL
I am having a problem getting the pistons I ordered (these: Sealed Power ZLW2601F30 - Speed-Pro Forged Pistons - Overview - SummitRacing.com) because they are on back order. So I was looking around to see what others I could get that are in stock and I found these: ICON Performance Pistons IC738-030 - ICON Premium Forged Pistons - Overview - SummitRacing.com
The ones on back order are flat top w/two valve reliefs. The others are dome w/two valve reliefs.
I am not sure if there is anything special I would need to consider if using the dome pistons or what, if anything, they would do for performance. I am just not educated on them to know if they would be fine for my 351W performance motor.
With the previous flat top pistons I was using (Keith Black/KB Pistons KB151030 - Keith Black KB Performance Pistons - Overview - SummitRacing.com) I measured 0.67" clearance between the intake valve and the top of the piston and 0.78" clearance on the exhaust side.
Any help/advice would be appreciated.
Thanks.
Old Jan 6, 2012 | 06:12 PM
UNTAMND's Avatar
UNTAMND
Are these going in your supercharged engine...
If so I'd try hard to stay under 9.5 compression depending on the amount of boost your running. Flat tops will get you close to that so I'd stay away from the domed ones.
Old Jan 6, 2012 | 06:18 PM
RIKIL's Avatar
RIKIL
It will be for the supercharged motor. I can easily stay under 9.5 if I get dome pistons.
greentruck72
May 4, 2015 04:02 PM
Uncle Grumpy
Mar 13, 2012 07:25 AM
Justins68ford
Jul 23, 2011 06:36 PM
351foxstang
Nov 30, 2005 09:05 PM
bootie
13
May 5, 2005 03:17 AM
