Help me choose a Piston PLEASE
Old Mar 12, 2012 | 08:52 PM
Uncle Grumpy's Avatar
Uncle Grumpy
hi,
I am tearing down my '90 5.8l motor. I am putting together my shopping list but am stuck with the pistons.
The stock pistons have the oval shaped dish that is .110 deep. Looking at Summit & Jegs the only ones like this are the expensive forged type. All the hyper or cast either are .140 or .190 deep.
I t is a sd efi motor am I not doing a radical rebuild so What do I do?
cheers
Old Mar 12, 2012 | 10:11 PM
restoringmy46's Avatar
restoringmy46
Get the hypher tech pistons. They are a flat top piston with the 4 valve relief. If your not building a race motor then I'd leave the forged pistons alone.
Old Mar 12, 2012 | 10:34 PM
Conanski's Avatar
Conanski
Nominal CR on a stock '90 5.8 was only about 8.8:1 which means the motor will run without detonation on the cheapest crap gas you can find, so you have some room to bump it up a little without risking the need for higher octane. My 5.8 has those flattops with 4 valve reliefs and it ran great.
Old Mar 13, 2012 | 07:25 AM
baddad457's Avatar
baddad457
The cast replacement pistons usually have a slightly deeper dish to keep the compression ratio at or near the same with an oversize piston. The .14 dish will be fine.
retired ironworker
Feb 8, 2015 10:38 AM
wvbogger
Apr 8, 2007 08:03 AM
bootie
13
May 5, 2005 03:17 AM
Ds7776
Sep 18, 2003 09:23 PM
