testing fuel pump
Old Jan 6, 2012 | 10:45 AM
jerrytown2001's Avatar
jerrytown2001
testing fuel pump
is there any way to test a fuel pump on 7.3 powerstroke 2001 f-250?
Old Jan 6, 2012 | 10:52 AM
woodnthings's Avatar
woodnthings
There are a few ways. You can turn the key on and listen for it, my take two people. The other way is to bring a power wire down to the FP and just manually apply power.
If you are looking for pressure, you can disconnect the output line (high pressure) and install a gauge in the outlet. This requires a special fuel line adapter, but they can be made by picking up an OEM line from a wrecking yard.
If you are just curious, you can open the fuel bowl drain and place a hose on it. Turn the key on and you should get a decent stream of fuel that is pressurized to flow.
Old Jan 6, 2012 | 10:57 AM
jerrytown2001
well the issue i am having is i am blowing the fuel pump fuse. i would like to test the pump to see if that is the problem or a short somwhere else.
66ca
52
Apr 15, 2012 04:43 PM
Florida Native 72
Dec 17, 2011 09:42 AM
capitanjo
20
Nov 24, 2011 03:18 PM
Big Brew
Jul 18, 2009 10:37 PM
gbetteley
Aug 19, 2003 10:52 PM
