Ignition Problem
Old Jan 5, 2012 | 01:28 AM
phukkaduck's Avatar
phukkaduck
Ignition Problem
Hey guys. I've been a lurker here for a while, now I need some help.
I have a very confusing problem. I'll start out from the first.
I thought I had a solenoid problem, I went and changed it like normal. It seemed to work but a few days later it was the same way again. For a few weeks now I've been having to start my pick up by jumping it at the solenoid. Then, a few days ago I tried starting it and it didn't start so I got out the screwdriver (extra special bend screwdriver that is haha) I use to jump it off with and thought the key was on. Well, after two tries I checked again and it wasn't. Anyway, it started up and ran fine until the next day when I put on a new solenoid because I thought it was still that at the time. I started it to check it then turned the key back and took it out. The truck was still on. I took the battery cable off, it shut off. So, I thought it was the ignition switch then. I got the switch today and accidentally came home with the lock also. Forgot to say, I messed with it and it seems to be "stuck" in the on position. Anyway, I put those on it tonight and it still is "stuck" in the on position.
Couple extra notes, my blower on my heat and AC went out while I've had these problems. Also, I can shut it off sometimes. I did it today while getting the part, matter-o-fact. Though I had to use a screwdriver because the tumbler wouldn't fit back in.
So, I'm thinking it's a wiring problem or my ignition module. Any ideas?
Old Jan 5, 2012 | 07:47 AM
fmc400's Avatar
fmc400
MSEE
Welcome to FTE! If I understand correctly, you're saying that even with a new ignition switch, shutting the key OFF and pulling it out does NOT shut the truck off? Or have you not replaced the switch yet?
Old Jan 5, 2012 | 07:03 PM
Myout's Avatar
Myout
I was having similar problems but with starting....started having to hold the shifter(automatic) while turning key..jiggling etc. Replaced alternator solenoid and a couple of other things. Would think we had it and then a couple of starts later it wouldn't. Ended up being the shift collar in the steering column was broken/breaking.
Forger
Aug 2, 2012 01:11 AM
Mrkoopa
1997 - 2003 F150
Jun 25, 2007 01:40 PM
EdsonFarm
Electrical Systems/Wiring
May 18, 2004 02:05 PM
EdsonFarm
May 17, 2004 09:33 PM
Sryaxxalot
15
Dec 4, 2002 12:02 AM
