Cruise swap Q's Help
Old Jan 4, 2012 | 02:44 PM
autoxbird's Avatar
autoxbird
Swapping cruise into my '91 250 Custom w/460, got all(?) the cruise stuff from a '91 XLT w/351. Got everything in, but when hitting the on button, the horn honks. Did I miss something or do something wrong? Help!
Old Jan 4, 2012 | 03:07 PM
SCRebel's Avatar
SCRebel
Kinda sounds like you might have a wire in the wrong place, or something.
Old Jan 4, 2012 | 03:12 PM
mpc07005's Avatar
mpc07005
When you press the horn button, does cruise work? Is this a wheel controlled cc or dash? Sounds like a wiring mixup.
-Mike
Old Jan 4, 2012 | 03:56 PM
autoxbird's Avatar
autoxbird
It's wheel controlled, the factory system. Is there anything different in the column between a non cruise and cruise truck. The donor truck also had a tilt column, where mine is a non tilt
Old Jan 4, 2012 | 04:02 PM
mpc07005's Avatar
mpc07005
If I'm remembering right all CC trucks had tilt. So I assume you changed the wheel over to get the buttons. The harnesses are not plug and play (apparently).
-Mike
Old Jan 4, 2012 | 04:08 PM
autoxbird's Avatar
autoxbird
I just took the pad. I'm not able to test if it's working as the cable to the TB is too short, the 351 must be shorter than the 460
Old Jan 4, 2012 | 07:28 PM
autoxbird's Avatar
autoxbird
Looked at a wiring diagram, I'm pretty sure I see what I missed. There's a signal amplifier that I believe I missed. Back to the 'yard
Old Jan 4, 2012 | 09:40 PM
SCRebel's Avatar
SCRebel
Try it and see what happens
Old Jan 5, 2012 | 12:42 PM
F150xlt's Avatar
F150xlt
The turn signal/hazard switch assembly is different between a tilt and non tilt
column. The horn wiring is different because in a tilt column when
you activate the horn button, it grounds the horn relay which closes
and provides 12 volts to the horns.
With a non tilt wheel there is no horn relay. When you activate the
horn button, 12 volts goes direct to the horns.
Also you need a Vehicle Speed Sensor. It's driven by the speedometer cable.
notacharger
Nov 8, 2016 05:26 PM
reamer
50
May 20, 2016 07:01 PM
wchain
Dec 28, 2009 03:47 PM
crazyeddie
Oct 12, 2009 10:32 PM
jdgreen72
Jul 2, 2007 05:26 PM
